Picture-elements card state-icon: trying to make a mdi:fan rotate on its axis, but can't be centered
Hi everybody,
in a picture elements card, the purpose is to place a state-icon that should rotate and spin to show that a fan is turned on.
I have card_mod installed.
I made the icon spin, but it doesnt spin on its axis and transform-origin seems to be useless.
after days I must surrender and ask help:
here s the code:
  - type: picture-elements
    image: local/y-07-bagnobianco.png
    title: null
    card_mod:
      style: >
        ha-card {
        color: black; background: white; box-shadow: none;
        @keyframes my-blink {
         from {opacity: 0;} to {opacity: 100;}
        from {opacity: 100;} to {opacity: 0;}
        @keyframes rotation{
                  0% {
                    transform: rotate(0deg);
                  100% {
                    transform: rotate(360deg);
         :host {
          --animation-07-02: {% if
        is_state('input_select.icona_smart_plug_bagno_bianco', '0') and
        is_state('switch.bagno_bianco_stufetta_o_ventilatore_locale_outlet','on')%}
        rotation 1s linear infinite  {% else %} none {%endif%}
    elements:
      - type: state-icon
        entity: switch.bagno_bianco_stufetta_o_ventilatore_template
        style:
          top: 1%
          left: 90%
          '--mdc-icon-size': 42px
          animation: var(--animation-07-02)
        tap_action:
          action: toggle
There is a special forum for card-mod questions:
Chek also this post by @Ildar_Gabdullin that has a lot of tips:
thank you !
Just check if your issue gets solved if you add this to your styles:
'--ha-icon-display': inline ## <-- this
Edit:
I think that if you change it to inline then you cannot change the size, so, it is better if you try to change the transform-origin in pixels:
transform-origin: XXXpx YYYpx
Start to change XXX and YYY pixel by pixel until you reach your sweet spot.
very interesting,
“display:inline” works!
both on desktop and samsung mobile companion app.
it would be interesting to clearify the reason of this behaviour.
display:inline should be used to align 2 css entiites inside a container,right?
so , what’s the other one?
