Below is picture on my card settings. the first 2 Light Elements work fine. The 3rd does not. i get element not available. The light works in an element card just fine. Any ideas?
Double check your 3rd entity ID in the states tab.
Guessing your issue is switch.switch. (double periods…)
If I remove the “switch.” then nothing shows on the plan. i copied the entity ID from the light card that works.
Non of my Icons are turning the light off?
