Picture_elements Heating Controller
Hi all,
I’ve been trying to create a picture_elements card to represent my heating/hot water controller - I’ve added the code below. The first two image elements are working fine and they are displayed as the ‘HW’ and ‘CH’ switches, in the image I’ve posted at the bottom. Pressing these turns my hot water or central heating on/off. I’m trying to create two more image elements that show the state of the HW/CH, since these switches could be on/off depending on my timer. Unfortunately, the last two image elements will not display. I thought it might be because they have the same entity_id’s but I’ve tried commenting each one out and they still don’t display; I’ve also tried giving each element its own ‘title’ as well, but that has no affect.
I was hoping that someone with a better grasp of all this could shed some light on where I’m going wrong.
  - type: picture-elements
    image: /local/Drayton_LP722.jpg
    elements:
      - type: image
        entity_id: switch.hot_water
        tap_action: call-service
        service: switch.turn_on
        image: /local/HW.jpg
        style:
          transform: scale(1.4)
          top: 36%
          left: 3%
      - type: image
        entity_id: switch.central_heating
        image: /local/CH.jpg
        style:
          top: 36%
          left: 82.5%
      - type: image
        image: /local/off.jpg
        state_image:
          'on': /local/on.jpg
        style:
          top: 0%
          left: 40%
      - type: image
        state_image:
          'on': /local/on.jpg
        style:
          top: 0%
          left: 50%
The syntax looks correct to me, I would try comment out all but the last image and change the top: 0% to like 50% just to see if it would display at all.
Hi JTPublic, I commented out various portions of the code last night and eventually found that it’s the state_image bit that’s causing me problems. I’ve looked at examples in the documentation that include this variable but for some reason it doesn’t work.
Is there any error or just not showing?
Maybe change the image to /local/CH.jpg to test the syntax since we know the first 2 worked?
No error, just not showing. I’ve had a play about and the picture at the bottom shows the result of commenting out state_image. (I’ve changed to .png images to get rid of a white background I was experiencing).
I can have both the last two images as on.png, off.png, or any combination and they display fine. As soon as I uncomment the state_image, the associated image disappears.
I get a feeling there’s something very basic I’m missing.
P.S. thanks for taking a look at this, I feel like I’m writing tongue-twisters when I read this back! :smile:
    elements:
      - type: image
        image: /local/HW.png
        style:
          transform: scale(1.01)
          top: 31.35%
          left: -0.4%
      - type: image
        image: /local/CH.png
        style:
          transform: scaleX(1.06) scaleY(1.01)
          top: 31.35%
          left: 80%
      - type: image
        image: /local/off.png
        # state_image:
          # 'on': /local/on.png
        style:
          top: 62%
          left: 25%
      - type: image
        image: /local/on.png
        # state_image:
          # 'on': /local/off.png
        style:
          top: 62%
          left: 75%
How about:
  - type: image
    state_image:
      'on': /local/on.png
      'off': /local/off.png
    style:
      top: 62%
      left: 75%
I’ve had a break through!! It’s because I used ‘entitiy_id’ but I needed to use ‘entity’. Your tip of using state_image: ‘on’ and 'off seems more sensible as well.
I knew it’d be something silly stopping it from working! I’ve posted the working code below.
If anyone else stumbles across this post TOP-TIP here!! Periodically delete your browser cache and restart home-assistant service while your trying to fix problems with Lovelace-UI.
Thanks for the suggestions JTPublic. Much appreciated :+1:
    elements:
      - type: image
        entity: switch.hot_water
        service: switch.turn_off
        style:
          top: 31.35%
          left: -0.4%
      - type: image
        entity: switch.central_heating
        style:
          top: 31.35%
          left: 80%
      - type: image
        state_image:
          'on': /local/on.png
        style:
          top: 62%
          left: 25%
      - type: image
        state_image:
          'on': /local/on.png
        style:
          top: 62%
          left: 75%
I saw a separate post from you showing someone how to get the date and time showing on a picture_element card, so I couldn’t resist the next step!
You meant this?
Just add a state-label with your favorite date/time sensor to your picture-element card and position it. I used my camera stream as image here:
        image: http://192.168.1.189:8082/video
        elements:
        - type: state-label
          entity: sensor.local_time
          style:
            top: 20%
            left: 60%
            font-size: 5vw
            font-weight: bold
            color: yellow
I saw a different post of yours, it had a picture of the Earth with black font for the time. I used that for inspiration and in the last picture of my temperature controller, you can see it’s the correct date and time (at the time)! It’s incredible what you can do with the combination of these cards. I’m sure I’ll be back soon looking for help though!! :laughing:
Lovelace has been amazing, nice looking control you have, btw.
I’ve really been having some fun with this Lovelace UI, so I thought I’d post a pic of the progress so far!
Only problem now is the family actually want rooms looking like this!! :grin:
title: Home
# Include external resources
resources:
  - url: /local/my-custom-card.js
    type: js
  - url: /local/my-webfont.css
    type: css
# Optional background for all views. Check https://developer.mozilla.org/en-US/docs/Web/CSS/background for more examples.
background: center / cover no-repeat url("/background.png") fixed
# Exclude entities from "Unused entities" view
excluded_entities:
  - weblink.router
    # View tab title.
  - title: Control
    # Optional unique id for direct access /lovelace/${id}
    # Optional background (overwrites the global background).
    background: radial-gradient(grey, skyblue)
    # Each view can have a different theme applied. Theme should be defined in the frontend.
    theme: dark-mode
    # The cards to show on this view.
    cards:
        # The picture entity card will represent an entity with a picture
        image: /local/living_room.png
        elements:
          - type: state-label
            entity: sensor.living_room
            style:
              top: 12%
              left: 12%
              font-size: 1.5vw
              color: black
          - type: state-label
            entity: cover.srv_l
            prefix: 'Radiator '
            tap_action: toggle
            style:
              top: 5%
              left: 85%
              font-size: 1vw
              color: blue
          - type: state-label
            entity: cover.srv_d
            prefix: 'Radiator '
            tap_action: toggle
            style:
              top: 40%
              left: 30%
              font-size: 0.6vw
              color: blue
          - type: state-icon
            entity: switch.cupboard_led
            tap_action: toggle
            style:
              top: 40%
              left: 62.5%
        image: /local/bedroom.png
        elements:
          - type: state-label
            entity: sensor.bedroom
            style:
              top: 12%
              left: 12%
              font-size: 1.5vw
              color: black
          - type: state-label
            entity: cover.srv_b
            prefix: 'Radiator '
            tap_action: toggle
            style:
              top: 5%
              left: 42%
              font-size: 1vw
              color: blue
        image: /local/isabels_room.png
        elements:
          - type: state-label
            entity: sensor.isabels_room
            style:
              top: 12%
              left: 12%
              font-size: 1.5vw
              color: black
          - type: state-label
            entity: cover.srv_i
            prefix: 'Radiator '
            tap_action: toggle
            style:
              top: 5%
              left: 80%
              font-size: 1vw
              color: blue
        image: /local/rowans_room.png
        elements:
          - type: state-label
            entity: sensor.rowans_room
            style:
              top: 12%
              left: 88%
              font-size: 1.5vw
              color: black
          - type: state-label
            entity: cover.srv_r
            prefix: 'Radiator '
            tap_action: toggle
            style:
              top: 5%
              left: 68%
              font-size: 1vw
              color: blue
        image: /local/Drayton_LP722.png
        elements:
          - type: image
            style:
              top: 49%
              left: 10%
          - type: image
            style:
              transform: scaleX(1.04)
              top: 31.35%
              left: 80%
              padding: 0px
          - type: image
            state_image:
              'on': /local/on.png
            style:
              top: 62%
              left: 25%
          - type: image
            state_image:
              'on': /local/on.png
            style:
              top: 62%
              left: 75%
          - type: state-label
            entity: sensor.time
            style:
              top: 46%
              left: 50%
              font-size: 2vw
              color: black
          - type: state-label
            entity: sensor.date
            style:
              top: 56%
              left: 50%
              font-size: 1vw
              color: black
          - type: image
            entity: input_boolean.heating_switch
            tap_action: toggle
            state_image:
              'on': /local/Auto_on.png
              'off': /local/Auto_off.png
            style:
              transform: scale(1.1)
              top: 72%
              left: 72%
              padding: 0px
      # - type: entities
        # entities:
          # - cover.srv_l
          # - cover.srv_d
          # - cover.srv_b
          # - cover.srv_i
          # - cover.srv_r
        # title: Radiators
        # show_header_toggle: false
  - title: Temperatures
    theme: dark-mode
    cards:
        # The filter card will filter entities for their state
      - type: entities
        title: General
        entities:
          - input_number.l_temp
          - input_number.b_temp
          - input_number.i_temp
          - input_number.r_temp
      - type: entities
        title: Temporary
        entities:
          - input_number.l_temp_temp
          - input_number.b_temp_temp
          - input_number.i_temp_temp
          - input_number.r_temp_temp
  - title: Map
    theme: dark-mode
    cards:
      - type: map
        entities:
          - device_tracker.####
    # Specify a tab icon if you want the view tab to be an icon.
  - icon: mdi:home-assistant
    # Title of the view. Will be used as the tooltip for tab icon
    title: Second view
    cards:
        # Entities card will take a list of entities and show their state.
      - type: entities
        # Title of the entities card
        title: Example
        # The entities here will be shown in the same order as specified.
        # Each entry is an entity ID or a map with extra options.
        entities:
          - light.kitchen
          - switch.ac
          - entity: light.living_room
            # Override the name to use
        # The markdown card will render markdown text.
      - type: markdown
        title: Lovelace
        content: >
          Welcome to your **Lovelace UI**.
Out of interest what’s controlling the radiators?
Hi badgerhome, I made a smart radiator valve using an esp-12 and a linear stepper motor. Here’s a link to the instructables
Unfortunately, the linear stepper motors are really difficult to get hold of now and are far more expensive. Hopefully there’ll be a cheap batch again soon.
:fu::fu: Love it.
:grin::grin::joy: that’s a bit harsh mate!! :+1:
Awesome work! I came across your write up a while back! Wish I’d ordered the parts when I had the chance now!
I’m going to test the EQ-3 Max valves but might end up using your project for the rads that have power nearby! Cheers
I did consider using batteries, since the esp-12 should be able to work for at least a year with the sleep mode. In fact, using a 9V battery would result in a more powerful drive on the stepper motor.
I’ll post an update if I manage to find reasonably priced components. I have found the same steppers but they’re about £16. When I bought them they were more like £2.60!
Awesome, keep me posted would love to give this a go :slight_smile:
