I’m trying to create a floor plan with all the lights and things that I have at home, but I’m having a couple of issues. Right now I’m using this code to do the tests:
The other issue that I have is that I cannot change the name of the entity, I tried with command “Title”, “Name”, “prefix”, sufix" but no luck. I add this line just below the Entity one. Such as:
width is not a valid field for the picture-elements card. Take a look at the documentation. It lists all available fields.
If you want to change the width of the card, you’ll need to use a custom card because the base picture-elements does not support this feature. The custom “card” called card mod will allow you to modify this.
All fields should be lowercase. title is correct, Title is not. Also, this is just for the tool tip, not the name that appears. If you want to change the name that appears, change the name of the sensor in the customize section or on your device page.
If you just want to modify this in the picture-elements card only, you’ll need a custom card. I can’t think of any card that does this but I’m sure others might have a custom solution.
Thanks for the name change in the sensor section that helped a lot and of other cards. Also if the idea was to leave it blank, but with the new name it helps.
Still having issues for the width of the icon inside the Picture Element.
