As you can see, there are some state-labels that display temperature.
This is done with
- type: state-label
title: Keukenraam
entity: sensor.my_n00_p03_temperature_t03_koelkast_temperature
double_tap_action:
action: more-info
style:
transform: scale(0.8,0.8) translate(-50%, -50%)
top: 63%
left: 90%
color: black
border: 1px solid black
border-radius: 20px
padding: 0px
background-color: white
Now what I want: on double_tap_action
double_tap_action:
action: more-info
I want to see the device info, not the entity info.
This is especially interesting when you have a device with multiple sensors, i.e. the most temperature sensors: temp/humidity
I don’t want to clutter my dashboard with all those details, but it can be interesting that you can see them on double tap.
Picture-element, Glance card , whatever - it does not matter.
The correct question is - “is there a card which displays a Device, not entities?”
Answer is - “there is no such a standard card”.
In HA Settings → Devices you can open a “Device info” popup which contains a device-level info and associated entities. But I do not know a way to call this pop for a particular device
Devices can be displayed using an auto-entities card using type:custom:template-entity-rows to add the devices. Presuming you have a device list with the device info like id, name area and model, this is the skeleton for the template in the auto entities card:
{%- set ns=namespace(rows=[]) -%}
{%- for info in devices -%}
{%- set sec_info = 'Area:'~info.area~', Mdl:'~info.model -%}
{%- set entry = {
'type': 'custom:template-entity-row',
'name': info.integration~': '~info.name,
'state': <your state>,
'secondary': sec_info,
'tap_action': {
'action': 'navigate',
'navigation_path': '/config/devices/device/'~info.id },
{%- set ns.rows= ns.rows + [entry] -%}
{%- endfor -%}
{{ ns.rows }}
