Picture is not being displayed
I’m having trouble displaying a picture on my dashboard. What am I doing wrong?
For images i am using this in configuration.yaml:
  allowlist_external_dirs:
    - /config/www
See here the example:
Try placing the image in /config/www and reference to it as /local/ (local points to /www)
so /config/www/cupra.png is the location and you reference to it as /local/cupra.png.
So, I’ve left the picture in media/cupra_born.png and the following works:
type: picture
image: local/cupra_born.png
So confusing…homeassistant has it’s weird things I guess.
My Home assistant doesn’t accept (it says to when I want to restart HA). I’ve tried it with “” etc, I’ve tried different folders. It’s not accepting it.
Does it matter that I’m running it on a VirtualBox VM on Windows?
It doesnt matter.
Try pasting the code in your config.yaml
ok, sorry, its like this:
homeassistant:
    - /config/www
You probably already have one homeassistant: , put it there
Thanks! I didn’t have “homeassistant:” mentioned anywhere in configuration.yaml, now it is indeed working.
Cheers
