Piecemealing Home Assistant Blue
Seeing that the Home Assistant Blue is on backorder and not knowing when it will be available, I decided to purchase the N2+ and load Home Assistant myself. My question is and I may be overthinking this what eMMC memory should I purchase for my setup? I’ve seen the preloaded eMMC with Linux https://www.hardkernel.com/shop/128gb-emmc-module-n2-linux-2/ and I believe this is what I needed. I would appreciate it if anyone could confirm if this is correct or recommend another memory chip.
It doesn’t matter whats pre installed on the emmc. Your going over write it with a HassOS anyway.
128gb is a good choice.
Just don’t forget the emmc writer!
Hope it’s of help.
Thank you! I figured I was overthinking it. Only problem now is that ameridroid does not have the 128gb eMMC in stock and who knows how long shipping from hard kernal will take.
What eMMC did you end up going with?
I am thinking of buying a standard 256Gb eMMC separately from somewhere else.
Also how did it take from order to getting it to your door?
