Piezo Buzzer too quiet (and volume control behaves weirdly)
I have this piezo buzzer module:
I tried with this config:
output:
  - platform: ledc
    pin: GPIO18
rtttl:
  output: buzzer
  gain: 50%
switch:
    turn_on_action:
      then:
        - rtttl.play: 'siren:d=8,o=5,b=100:d,e,d,e,d,e,d,e'
    turn_off_action:
      then:
        - rtttl.stop:
The problem is the sound is barely audible and also the volume control behaves weirdly, I get the max volume with gain at 50%, but if I set higher (for example 90%) or lower (for example 20%) it actually gets quieter…
So I desoldered the actual piezobuzzer (the black circular thing) from the small board and connected directly one leg to GND and the other to one GPIO (as stated by esphome documentation, read the code), and copy pasted the following configuration:
# Configure the output
output:
  - platform: ledc
    # One buzzer leg connected to GPIO12, the other to GND
    pin: GPIO18
    inverted: True
switch:
    turn_on_action:
      then:
        # Must be turned on before setting frequency & level
        - output.turn_on: buzzer
        # Frequency sets the wave size
        - output.ledc.set_frequency:
            frequency: "1220Hz"
        # level sets the %age time the PWM is on
        - output.set_level:
            level: "50%"
    turn_off_action:
      then:
        - output.turn_off: buzzer
But the problem is the same. I would think that the buzzer itself is quiet but the fact that increasing the volume in configuration make the actual volume lower makes me think I’m doing something wrong.
Any suggestion?
They are selling that same module as active and passive buzzer, so generally you don’t really know what you have. But you disassembled that so you should know. Did that buzzer has a circuit underneath?
I know for sure is passive, cause its playing what I tell it, only at low volume
EDIT: and yes it has a simple circuit, only a transistor (I believe?) and a resistance
Ok, then I don’t have anything to help you. Just wait for the next one…
