I have just installed and tested the piglow module using python and it works correctly
I have enabled it in my config
light:
platform: piglow
as per
I then run a check config from the config tab and it comes back as ok
I then run hass --checkconfig comes back find
then i run reload core, nothing happens that I can see
I then restart the service and see this in the logs
17-03-02 18:35:09 INFO (MainThread) [homeassistant.loader] Loaded light.piglow from homeassistant.components.light.piglow
17-03-02 18:35:09 INFO (MainThread) [homeassistant.bootstrap] Setting up light
17-03-02 18:35:09 INFO (MainThread) [homeassistant.components.light] Setting up light.piglow
and the restart hangs, service fails to start, I am waiting right now to see if it fails out or not. it has been about 5 minutes so far
No. I don’t autostart it I just installed it manually outside Hass. But I’d like having the dev of this component here telling us how he got this component running in a venv
