Pigpio Addon
Today I’m starting to bring up my addons also to the Home Assistant community forum. The first one is:
pigpio
Logo
Wraps the C control lib pigpio in a Home Assistant addon to allow an easy installation on a Home Assistant OS system.
Addon Stage Supports aarch64 Architecture Supports amd64 Architecture Supports armhf Architecture Supports armv7 Architecture Supports i386 Architecture
Add repository on my Home Assistant Install on my Home Assistant Donate
Normally pigpio needs to be installed on the Pi running Home Assistant to interact with the GPIO pins. When running Home Assistant with the Home Assistant OS this is not possible in an easy way. This addon changes this and makes a pigpio daemon available on port 8888. In combination with the gpio integrations the pins can now be controlled and read.
To the Addon: GitHub - Poeschl-HomeAssistant-Addons/pigpio: Control your pwm leds with pigpio on Home Assistant
To the PWM integration (I use this): Removed integration - Home Assistant
If issues occur please use the GitHub issue board, since I’m only on the community forum from time to time.
