Pihole on HassOS, possible?
Hi
is it possible to install PiHole on HassOS ?
I’ve installed HassOS for Intel NUC and since Pihole addon is deprecated, I would like to know if it’s possible to install on HassOS.
Anyone tried?
Without the add-on, it is not possible. Hassos is very restricted.
If I install in a docker container do you think should be fine, since HassOS uses docker?
Install the portainer add-on, and use portainer to install the pihole container.
I have Portainer addon, but there is no template for PiHole.
I will search fo a guide…
https://hub.docker.com/r/pihole/pihole/
