Curious why the stats are showing unavailable. I just added the config and it sees the sensors but no data. It appears I cant get an API key unless I set a password? Is it needed or no?
SOLVED!
SOLVED!
How did you solve it?
Had to use the IP. Using localhost didn’t seem to work.
