Yes, I see the same. Very weird. I checked the hotfix with 32.0 and it seemed to work, this is maybe another bug.
Hi David,
This is what I found out:
The message says json {‘protocol’: [‘kaku_switch_old’], ‘unit’: 1, ‘id’: 1, ‘on’: 1}
But when i test a pilight send service with: {“protocol”: [“kaku_switch_old”], “unit”: 1, “id”: 1, “on”: 1}
it does work
Ok THX. Maybe the event data was changed. I’ll look into that.
@DavidLP Can you please explain what is the function of on_code_receive and off_code_receive? What is the usecase?
Below is a part of my configuration. But it seems to work with and without the code.
switch:
- platform: pilight
switches:
Staande lamp:
on_code:
protocol: kaku_dimmer
unit: 0
'on': 1
dimlevel: 2
off_code:
unit: 0
'off': 1
Witte lamp:
on_code:
protocol: kaku_switch
unit: 1
'on': 1
off_code:
unit: 1
'off': 1
on_code_receive:
unit: 1
state: 'on'
echo: false
off_code_receive:
unit: 1
state: 'off'
echo: false indent preformatted text by 4 spaces
hey,
i’m also new to HA and Pilight and want to install both on one Pi (my RPi Zero W). Hass.io is running fine, but what do i have to do to install Pilight? I read some posts above, that you have to install it from source. What does that mean (sorry, I’m a newbie ) Is installing pilight from source described at the end of this guide?
http://manual.pilight.org/installation.html
Thanks!
Just seen this and thought I’d answer it tho’ you probably know by now, the on/off_code_receive is for when you have a remote that is switching the target on/off, it means HA and the target stay in sink when a remote is used.
I don’t think you can install pilight under Hassio, with Hassio you use docker addons so if no one has written one you will have to write it yourself.
Hey guys, I feel a little like I’m banging my head against a wall here. I’d appreciate any input!
I’ve got pilight, homeassistant and Alexa Voice service installed on a Pi3, HA is installed in virtual env.
I’ve got various rf sockets that I control using HA with homebridge and/or alexa. All working nicely. But I want to be able to use a remote too, so that if I have a guest staying they can use a remote control to operate said lights and this then update in HA. I also want to add further RF stuff like door and weather monitoring etc, but I can’t get HA to receive from pilight.
The Pilight gui reflects my remote control operating, and it works when using HA dashboard. But when I use the remote, it doesn’t update the HA dashboard with whether it’s on/off.
Firstly, here’s my pilight config.json:
"devices": {
"ambilight": {
"protocol": [ "kaku_switch" ],
"id": [{
"id": 5628626,
"unit": 1
"state": "off"
"rules": {},
"gui": {
"ambilight": {
"name": "ambilight",
"group": [ "Lights" ],
"media": [ "all" ],
"readonly": 0
"settings": {
"log-level": 6,
"pid-file": "/var/run/pilight.pid",
"log-file": "/var/log/pilight.log",
"webserver-enable": 1,
"webserver-root": "/usr/local/share/pilight/webgui",
"webserver-http-port": 5001,
"webserver-https-port": 5002,
"webserver-cache": 1,
"port": 5000,
"gpio-platform": "none"
"hardware": {
"433nano": {
"comport": "/dev/ttyUSB0"
"registry": {
"webserver": {
"ssl": {
"certificate": {
"secure": 0,
"location": "/etc/pilight/pilight.pem"
"pilight": {
"firmware": {
"version": 1,
"lpf": 8,
"hpf": 1600
"version": {
"current": "8.0.8"
Here’s my HA configuration.yaml:
pilight:
host: 127.0.0.1
port: 5000
My switch.yaml:
- platform: pilight
switches:
Ambilight:
on_code:
unit: 0
'on': 1
off_code:
unit: 0
'off': 1
on_code_receive:
unit: 0
state: 'on'
echi: false
off_code_receive:
unit: 0
state: 'off'
echo: false
Here’s my output from pilight-receive:
"message": {
"id": 5628626,
"unit": 1,
"state": "on"
"origin": "receiver",
"protocol": "arctech_switch",
"uuid": "0000-b8-27-eb-09d9a5",
"repeats": 1
"message": {
"id": 5628626,
"unit": 1,
"state": "off"
"repeats": 1
So when I operate the switch in HA, it operates the switch in plight gui. But if i use the remote, it operates the pilight gui but doesn’t update the HA dashboard.
Any idea where I might be going wrong? Thanks!
This is probably supposed to be echo I think
Thanks Keith, you know how you stare at code for so long and miss the obvious!
Well unfortunately it made no difference.
I don’t see why it shouldn’t be working, I don’t get any errors in homeassistant.log. Weirdly if I run pilight-daemon -d when pilight isn’t running it stops picking up the remote and HA’s dashboard button but only responds to the pilight gui which does give output.
It’s my understanding that with the pilight details in HA configuration.yaml that whenever pilight picks up a remote signal it dumps it on HA’s event bus, is there anyway to see whether that’s actually happening?
I thought i’d have a go with using automation to try and switch an existing HA switch. So added this to my automations.yaml:
- alias: "lamp off"
initial_state: true
hide_entity: false
platform: event
event_type: pilight_received
event_data:
uuid: 0000-b8-27-eb-09d9a5
unit: 1
state: 'off'
- service: homeassistant.turn_off
entity_id: switch.lounge_lamp
- alias: lamp on
initial_state: true
hide_entity: false
platform: event
event_data:
unit: 1
state: 'on'
This doesn’t give me anything either so assuming that HA isnt’t getting anything from pilight. Hmm, i’m stumped.
Maybe try changing the echo: false to true, so that pilight will send the code out again, then It might tell HA about it?
EDIT: Spotted it I think your unit in the yaml is wrong
Thanks for your input Keith, that wasn’t actually it but you pointed me in the right direction. The unit was down to me messing with different configs/switches. Mate, i’m so chuffed, now I can use it for other stuff too.
I can point where I went wrong. So I looked into the echo option, and found this thread. Davidlp explains its use. But I noticed from his config how he had a different protocol for on_code and on_received_code. My switch protocol was showing up under pilight-receive as arctech_switch, but couldn’t get it to work to send with that, as pilight uses kaku_Switch. I changed my on_code_receieved to arctech_switch and boom, she works! Hurrah!
So my final switch.yaml looks like this, just for clarification if anyone else comes stumped on the same thing.
- platform: pilight
switches:
Ambilight:
on_code:
unit: 1
'on': 1
off_code:
unit: 1
'off': 1
on_code_receive:
protocol: arctech_switch
unit: 1
state: 'on'
echo: true
off_code_receive:
unit: 1
state: 'off'
echo: true
Thanks for your help Keith, I appreciate your time and input mate, many thanks!
No worries glad you got it working, I have lot of respect for pilight it’s a great piece software BTW mark it as solved so anyone can find it
According to the pilight documentation protocol kaku_switch uses option “state” but then when defining the entry on the configuration.yaml we make use of ‘on’/‘off’ instead of “state”. What is that I have missed in the documentation?
The reason for asking is that I made use of state: 'on'
and state: 'off'
on the configuration.yaml file and obviously I could not get it to work.
I have installed Pilight on a second Raspberry Pi.
On my other Pi i have write in the configuration.yaml:
pilight:
host: 192.168.1.107
port: 5000
But it dont works
Pilight will not find in Home Assistant.
When i write in the /etc/pilight/config.json file
„port“: 5000
and then rebooting the Pi is it always delete.
- in PIlight you have to change settings when Pilight is stopped, otherwise it will overwrite the config on shutdown.
- Until now I never received updates from pilight sensors, i only can send switch commands to Pilight
