Pilight partially working on Hassbian - Stuck, please help/advise
I’m running Hassbian on Rpi3. I’ve installed pilight-damon and here is my config.json
        "devices": {},
        "rules": {},
        "gui": {},
        "settings": {
                "log-level": 6,
                "pid-file": "/var/run/pilight.pid",
                "log-file": "/var/log/pilight.log",
                "webserver-enable": 1,
                "webserver-root": "/usr/local/share/pilight/webgui",
                "webserver-http-port": 5001,
                "webserver-https-port": 5002,
                "webserver-cache": 1,
                "gpio-platform": "raspberrypi3",
                "port": 5000
        "hardware": {
                "433gpio": {
                        "sender": 0,
                        "receiver": 2
        "registry": {
                "webserver": {
                        "ssl": {
                                "certificate": {
                                        "secure": 0,
                                        "location": "/etc/pilight/pilight.pem"
                "pilight": {
                        "version": {
                                "current": "8.0.8"
Here is my configuration.yaml
pilight:
  host: 192.168.1.60
  port: 5000
  whitelist:  # optional
    protocol:
      - clarus_switch
Here is my switch config:
switch:
  - platform: pilight
    switches:
      Cat Room:
        on_code:
          protocol: clarus_switch
          unit: 7
          'on': 1
        off_code:
          unit: 7
          'off': 1
        on_code_receive:
          unit: 7
          state: 'on'
        off_code_receive:
          unit: 7
          state: 'off'
When I set everything up I ran pilight-receive and got my codes for my Cat Room switch, but it only worked once and has not worked since.
        "message": {
                "id": "E3",
                "unit": 7,
                "state": "on"
        "origin": "receiver",
        "protocol": "clarus_switch",
        "uuid": "0000-b8-27-eb-6cd028",
        "repeats": 1
Seems the receiver quit working, but it does still work when I run the rpi-rf utilities.
BUT, when I stop the pilight service and run pilight-debug and push a remote button, I do get raw codes.
I just don’t know where to go from here to debug…
Got a similar problem here: Receiving works a while after hass has started, but then stops working…
Any progress on this?
I’m having the same problem. Any updates?
