New to HA so likely an operating error, but I am stuck for now.
Looking to switch from OpenHAB and have most of my (limited) configuration up and running; however I seem to have trouble with RF controlled switches. I am running a pilight server and have installed the platform and switches on HA successfully. I need two protocols, elro_800 and clarus.
- The elro works as expected, except that the UI does not update if I use a remote control; I would have expected HA to pick up and show the change in status when using pilight.
- the clarus switch seems to require an id value that is composed of a letter and a number (https://wiki.pilight.org/doku.php/clarus) but HA allows integers only; without the id the switch does not react
Would anyone have some info or ideas? Thanks much!
[edited as I accidentally posted unfinished post]
