I also have the problem for days with the error message!
Unfortunately I can’t fix it by adding (allow_other_uses: true)
This gives me a new error message
Thank you for this, this was the solution for me as well!
Please don’t post photos of text. I think you want
platform: pulse_counter
pin:
number: 13
With the risk of being told to read the documentation, I have, and am not an experienced coder, so…
Although this recommendation does work for some devices (I successfully fixed one device using this), it does not seem to work for:
- platform: ultrasonic
This is my code for the ultrasonic sensors before adding any fixes:
- platform: wifi_signal
name: "Sump Pit Water Depth Sensor WiFi Signal"
update_interval: 60s
trigger_pin: GPIO14
echo_pin: GPIO12
unit_of_measurement: "%"
icon: "mdi:water-percent"
accuracy_decimals: 0
update_interval: 5s
name: "Sump Pit Water Depth"
filters:
- lambda: return ((0.53-(x-0.03))/0.53)*100;
- filter_out: nan
trigger_pin: GPIO14
echo_pin: GPIO12
update_interval: 5s
name: "Water in Tank"
unit_of_measurement: "l"
filters:
- lambda: return (1-((x-.03)/0.53))*108;
- filter_out: nan
When I try to add allow_other_uses: true
it flags an error:
[allow_other_uses] is an invalid option for [sensor.ultrasonic]. Please check the indentation.
If I indent it one tab it throws the following error at line 1 of the code:
Invalid YAML syntax: mapping values are not allowed in this context in “”, line 47, column 23
Any suggestions are appreciated.
I must admit that I re-used Pieter Brinkman’s water meter code, but looking at the HA Energy Dashboard it seems that the Pulse counter is not of importance, except for debugging/calibration purposes. Water meter total is the only measurement used for the dashboard.
Unfortunately I’m unable to test the code currently.
How did you try to add allow_other_uses: true? Following the the same syntaxis as for the pin: schema this would be the correct syntax I suppose:
trigger_pin:
number: GPIO14
echo_pin:
number: GPIO12
update_interval: 5s
filters:
- filter_out: nan
trigger_pin:
number: GPIO14
echo_pin:
number: GPIO12
update_interval: 5s
filters:
- filter_out: nan
Awesome, thank you @MJV that worked perfectly. As I said, still learning and wasn’t aware the pin’s could be listed both ways (inline and indented below).
You don’t need to use ultrasonic twice. Once you have the distance you can calculate the rest with a template sensor.
Can you give an example to do this?
What I had in mind is something like this
trigger_pin:
number: GPIO14
echo_pin:
number: GPIO12
update_interval: 5s
internal: true
lambda:
return ((0.53-((id(waterdist).state)-0.03))/0.53)*100
trigger_pin:
number: GPIO14
echo_pin:
number: GPIO12
update_interval: 5s
lambda: return (1-(((id(waterdist).state)-0.03)/0.53))*108
Or alternatively a copy sensor…
Typically I have the “raw” sensor which I mark as internal after set-up/debugging and then use copy sensors with filters for the processed results. I find it clean to debug and maintain like that.
I edited my last post, the idea is to use the ultrasonic sensor once only, give it an id and then refer to it by id for further calculations. I may have some indentations etc wrong, but the idea is there.
I am not overly familiar with the copy integration, but Mr Mahko is often right.
I’d just like to emphasise that only using ‘allow_other_uses=true’ didn’t work for me (first snippet below, wrong)
pin: GPIO13
I had to rearrange the sensor (advanced mode) and use ‘number’ too:
pin:
number: GPIO13
Maybe this hint saves some time for someone as inexperienced as me.
The same thing was covered just a few posts back: Pin is used in multiple places - #47 by MJV.
You either have a simple pin definition using only the pin number, or you have a pin section with several options under it. Your’s is an invalid combination.
Yes, just like it says in the docs!
Nope. Why would they do that when they can come here and have someone explicitly answer their question or write their code without having to make the slightest effort to help or educate themselves.
Hi Rob,
I am not an expert, but guess this is a question how you define your pin. I originally had the pin: A0 with same error likey you had when adding “allow_other_uses: True”. I then changed pin definition like below in alle places.
- platform: adc
# pin: A0
pin:
number: GPIO17
Very nice, thanks for the hint Oldacres, it works now, herewith entire code for the easy way
- platform: pulse_counter
pin:
number: GPIO18
update_interval : 6s
- platform: pulse_meter
pin:
number: GPIO18
unit_of_measurement: 'liter/min'
name: 'Water Pulse Meter Liter'
icon: 'mdi:water'
total:
unit_of_measurement: 'liter'
pin:
number: GPIO18
name: "Water Pulse Meter"
unit_of_measurement: "liter/min"
icon: "mdi:water"
total:
name: "Water Meter Total"
unit_of_measurement: "m³"
accuracy_decimals: 3
device_class: water
state_class: total_increasing
filters:
- multiply: 0.001
name: "Water Usage Liter"
accuracy_decimals: 1
unit_of_measurement: "l/min"
icon: "mdi:water"
lambda: return (id(Water_pulse).state * 10);
update_interval: 5s
I have no idea why multiple pin uses is such a common issue. Theres only a few cases where that would be OK to do and thats only if the Copy integration or a Template wont work. Why someone would use the same ADC pin twice, i surely have no idea about that one.
