PineCube from Pine64...likely to work with HA?
I know that it’s still in a pre-release state, but from what’s known so far, is the PineCube open source IP Camera being made by Pine 64, likely to work with Home Assistant?
For those curious, the specs are in the link above, with more in depth details on their wiki page
#PineCube #Pine64
Why wouldn’t it? If it’s open source I’d wager your chances are 10x higher since developers won’t need to spend nearly as much time reverse engineering a proprietary device or API.
I honestly don’t know.I just thought that being new it might require some work to support that hadn’t been done yet. I’m not sure what - if any - work would be required though as I don’t have much experience in this space.
