I know the ping device track isn’t the best solution, but the only option for me right now.
After configuring it, it worked great for a couple of weeks. Then it suddenly stopped in the middle of the night, and both our devices went ‘away’. After rebooting it worked again.
Two days later, it suddenly broke again in the middle of the night.
Correct. This is how mine is setup. Since you’re on hass.io, you could leave off the scan_options (I think?). I only care about 3 IPs, so I use the range 200-202.
Yeah, that’s a reboot of HA. Are you connected via WiFi or ethernet? I’m wondering if maybe the port is timing out or the interface from HA to the network.
Hass.io is running on a Rpi with ethernet connection. You would say that in case of a timeout or something, he should pick it up again automatically… but it doesn’t.
I will try NMAP later, and see how it goes. Thanks!
Hmmm, I’d look at her WiFi settings and make sure that it’s not turning off the radio. Android has an annoying “feature” that will wake up the WiFi radio for short periods when the device is sleeping.
At a minimum, I’d turn off “WiFi power saving mode” and “Turn on WiFi Automatically”.
