Ping device tracker
I seem to be unable to use the device tracker that is created through the ping integration in the UI with the person integration. I can choose it from the drop down menu., when I do the person disappear in the automation UI. I tried on two instances of home assistant with no luck. Anyone else is having the same issue?
Thank you
Tell us how you installed Home Assistant
Are you using this Ping Integration: Ping (ICMP) - Home Assistant?
I am running the latest version of home assistant on a vmware. I am using the official ping integrations. It works perfectly, I even have guest profiles based on the ping integration and ip reservation on my router. The device tracker entity indicate when am home or away. The issue is I can’t use the ping device trackers in my person entity. I can add it but then my person entity diapers when I want to select it in automations
