Does anyone have a working config for ping and NMAP? I’ve been trying to use both of these for a while now, and while it looks like it is working, if a device is offline for sometime, it will still show as ‘home’. I’ve tried deleting the devices from known_devices.yaml and while this seems to then work for a bit, the issue then starts again.
I saw the following bug - https://github.com/home-assistant/home-assistant/issues/10231, which looks to be my exact issue, but I am using 0.68.0 so this should be resolved.
In both ping and NMAP I have defined the hosts (all with static IP addresses) and have tried hide_if_away = true as that was mentioned on another thread that it may resolve the issue.
Regarding ping, I have enabled debug and can see that the ping is not finding the device (No response from 192.168.7.50 failed=1), but it still stays as ‘home’.
My config:
platform: nmap_tracker
hosts:- 192.168.7.50
- 192.168.7.51
- 192.168.7.52
- 192.168.7.53
track_new_devices: yes
interval_seconds: 30
hide_if_away: true
home_interval: 10
scan_options: " -sP --host-timeout 10s"
exclude: - 192.168.7.124
platform: ping
hide_if_away: true
hosts:
s_s6_ping: 192.168.7.50
p_iphone_ping: 192.168.7.51
c_iphone_ping: 192.168.7.52
b_iphone_ping: 192.168.7.53
