It would be nice to have a ping sensor that would store the latency.
(This is not the same as the Ping device tracker, but the code could be almost the same but some parsing would be needed and a target hostname).
https://github.com/home-assistant/home-assistant/pull/7052
Would be nice if you could test it and give some feedback directly in the Pull request. Thanks.
I’ve seen the new Ping (ICMP) Binary Sensor in V0.43 (https://home-assistant.io/components/binary_sensor.ping/).
Is it possible to provide multiple IPs / hostnames when using it? If so: how?
Thanks!
Answering my own question here. I used the following in my included binary sensor yaml file:
- platform: ping
host: bla1.home.tld
name: Device Name Nr 1
- platform: ping
host: 192.168.1.2
name: Some other cool device
Thanks for the sensor, it works as intended!
Im using it the following way
binary_sensor:
- platform: ping
host: 192.168.0.1
- platform: ping
host: www.google.com
- platform: ping
host: bahnhof.se
sensors:
router:
value_template: '{% if is_state("binary_sensor.router", "on") %} {{ states.binary_sensor.router.attributes.round_trip_time_avg }} {% else %}Offline{% endif %}'
unit_of_measurement: 'ms'
google:
value_template: '{% if is_state("binary_sensor.google", "on") %} {{ states.binary_sensor.google.attributes.round_trip_time_avg }} {% else %}Offline{% endif %}'
bahnhof:
value_template: '{% if is_state("binary_sensor.bahnhof", "on") %} {{ states.binary_sensor.bahnhof.attributes.round_trip_time_avg }} {% else %}Offline{% endif %}'
homeassistant:
customize:
binary_sensor.google:
hidden: true
sensor.google:
friendly_name: 'Google'
icon: mdi:google
binary_sensor.bahnhof:
hidden: true
sensor.bahnhof:
friendly_name: 'Bahnhof'
icon: mdi:web
Result:
I believe there may be a small issue, then again I could be mistaken.
When I first installed it used to show the attributes in the panel when you expanded the entity.
Now they are missing. Not a big deal. They are still available for extraction but it was nice seeing them at a glance…
