I have a Beca BHT-002 with TuyaMCU flashed with ESPHome which works but I’m only seeing the datapoints exposed by the TuyaMCU. I’m missing quite a few things like for example the relay that switches the valve of the heating system.
Would it be possible to get these values anyway? Maybe directly through the pins? Any tips on what I need to do?
The thing is, as mentioned there seems to be less datapoints than what the functionality is. I also don’t see the valve state in the Tuya app for example.
The two main things i’m missing is the valve switch and the current state. Hence, i was wondering if there are ways to go behind the TuyaMCU and read the raw gpio pins on a tuya device.
