Pioneer receiver VSX 933 control
I have a Pioneer VSX 933 and I am trying to add it in Home Assistant.
I used to use Domoticz only, but I want to switch to Home Assistant so I have now one Raspberry Pi with domoticz running and one with Home Assistant.
In Domoticz I was able to control it using the onkyo-eiscp commands.
In Home Assistant I tried to control it using the Pioneer and Onkyo add-ons, but no luck (yet, hopefully).
These are the errors I get:
2020-02-11 09:02:44 WARNING (SyncWorker_19) [homeassistant.components.pioneer.media_player] Pioneer receiver refused connection
2020-02-11 09:02:44 ERROR (SyncWorker_11) [homeassistant.components.onkyo.media_player] Unable to connect to receiver at 192.168.x.xxx
For the Pioneer add on I tried ports 23, 8102 and 60128. All throw the same error.
How can I get it to work?
Does anybody know how I can get this working?
Hi
i use the onkyo integration for my VSX1131 using the below
media_players:
  - platform: onkyo
    host: 192.168.168.70
    receiver_max_volume: 164
    sources:
      Blueray: 'Fire TV'
      Video 2: 'PS4'
      Video 3: 'PC'
      network: 'spotify'
More info for setting volume and inputs on
I changed media_players to media_player and added this to the configuration:
media_player:
  - platform: onkyo
    host: 192.168.2.200
This is what returns in the log:
Unable to connect to receiver at 192.168.2.200
14:24 components/onkyo/media_player.py (ERROR)
So it doesn’t work… Do you know why this is the problem?
is .234 your receiver and .200 your HA?
with your receiver on does the eiscp give you if you run this
onkyo --host 192.168.2.234 source=query
The official component had issues with my model and now Im using this custom component and is working great!
media_player:
  - platform: pioneer_vsx529
    host: 192.168.0.203
    port: 8102
    sources:
      'DVD': '04'
      'TV': '05'
      'SAT/CBL': '06'
      'BR': '15'
      'VIDEO': '10'
      'BD': '25'
      'Webradio': '38'
      'PANDORA': '41'
Do I need to SSH access to the host to do this or can I do this with the SSH add-on?
It needs to be run in the instance so that depends on your install. it will either be ssh or if you have it running within docker you can possibly access console.
I am using hassio. I have followed this: https://developers.home-assistant.io/docs/en/hassio_debugging.html and I have SSH access via the SSH add-on and also access to the host as explained on that page.
I logged in with “login” on the host and tried this:
ha > login
# onkyo
/bin/ash: onkyo: not found
However, it doesn’t find onkyo.
And this is in my configuration:
media_player:
  - platform: onkyo
    host: 192.168.2.200
Does someone know why it isn’t working? Shouldn’t the onkyo commands be available?
Hello
Have you tried https://www.home-assistant.io/integrations/pioneer/
That doesn’t work for me.
Does anyone know what intergration i need for the VSX 828 (2014)
I used the the Pioneer intergration but cant seem to send any media to it using Home Assistant media
and i can seem to controll the volume but it doesn’t show on the Pioneer display
Thanks this works perfect for my VSX-828
