Has anyone managed to install Piper and Whisper on Synology 6.2.4? If you could share your docker-compose, it would be greatly appreciated.
I was able to get Piper to run with this docker-compose, but still having trouble with Whisper:
services:
piper:
container_name: piper
image: rhasspy/wyoming-piper
command: --voice en-us-lessac-low
volumes:
- /volume1/docker/piper/data:/data
environment:
- TZ=America/Chicago
restart: unless-stopped
ports:
- 10200:10200
When I try the following docker-compose for Whisper:
services:
whisper:
container_name: whisper
image: rhasspy/wyoming-whisper
command: --model base-int8 --language en
volumes:
- /volume1/docker/whisper/data:/data
environment:
ports:
- 10300:10300
I get the following error:
/run.sh: line 5: 7 Illegal instruction (core dumped) python3 -m wyoming_faster_whisper --uri 'tcp://0.0.0.0:10300' --data-dir /data --download-dir /data "$@"
For what it’s worth, it seems this may have been a problem with the upstream image maybe? I just created a folder at /volume1/docker/whisper/data and used your docker-compose with no adjustments and everything started up just fine. Perhaps they corrected whatever the problem was.
This was on a DS923+ with DSM 7.2
@cryptk thanks for letting me know my docker-compose wasn’t messed up. I ended up setting everything up on a mini PC so that I could run Frigate and Double Take with a Coral. Good to know that I could go back to using Synology for Home Assistant if I needed to though.
