Piper text-to-speech won't run without internet access? Log file inside
I’m trying to run my Home Assistant on a network that isn’t connected to the internet, and it seems like that’s preventing Piper from even starting up. It works fine when I run it on an internet-connected network, but if I run it on just my LAN, it fails.
Here’s the log file, which I think indicates that the program is failing because it can’t reach the internet. Any way to fix this?
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service piper: starting
s6-rc: info: service piper successfully started
s6-rc: info: service discovery: starting
File “/usr/lib/python3.11/urllib/request.py”, line 1348, in do_open
h.request(req.get_method(), req.selector, req.data, headers,
File “/usr/lib/python3.11/http/client.py”, line 1282, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/lib/python3.11/http/client.py”, line 1328, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/lib/python3.11/http/client.py”, line 1277, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.11/http/client.py”, line 1037, in _send_output
self.send(msg)
File “/usr/lib/python3.11/http/client.py”, line 975, in send
self.connect()
File “/usr/lib/python3.11/http/client.py”, line 1447, in connect
super().connect()
File “/usr/lib/python3.11/http/client.py”, line 941, in connect
self.sock = self._create_connection(
File “/usr/lib/python3.11/socket.py”, line 827, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File “/usr/lib/python3.11/socket.py”, line 962, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
File “”, line 198, in _run_module_as_main
File “”, line 88, in _run_code
File “/usr/local/lib/python3.11/dist-packages/wyoming_piper/main.py”, line 193, in
asyncio.run(main())
File “/usr/lib/python3.11/asyncio/runners.py”, line 190, in run
return runner.run(main)
File “/usr/lib/python3.11/asyncio/runners.py”, line 118, in run
return self._loop.run_until_complete(task)
File “/usr/lib/python3.11/asyncio/base_events.py”, line 653, in run_until_complete
return future.result()
File “/usr/local/lib/python3.11/dist-packages/wyoming_piper/main.py”, line 161, in main
await process_manager.get_process()
File “/usr/local/lib/python3.11/dist-packages/wyoming_piper/process.py”, line 114, in get_process
ensure_voice_exists(
File “/usr/local/lib/python3.11/dist-packages/wyoming_piper/download.py”, line 137, in ensure_voice_exists
with urlopen(file_url) as response, open(
File “/usr/lib/python3.11/urllib/request.py”, line 216, in urlopen
return opener.open(url, data, timeout)
File “/usr/lib/python3.11/urllib/request.py”, line 519, in open
response = self._open(req, data)
File “/usr/lib/python3.11/urllib/request.py”, line 536, in _open
result = self._call_chain(self.handle_open, protocol, protocol +
File “/usr/lib/python3.11/urllib/request.py”, line 496, in _call_chain
result = func(*args)
File “/usr/lib/python3.11/urllib/request.py”, line 1391, in https_open
return self.do_open(http.client.HTTPSConnection, req,
File “/usr/lib/python3.11/urllib/request.py”, line 1351, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno -3] Temporary failure in name resolution>
[16:22:26] INFO: Service exited with code 1 (by signal 0)
