Piper tts responses not working
I noticed that when using this to get my ESPMuse Luxe working as voice assistant input that I wasn’t getting the tts response with my commands. Looking at the logs for ESPHome I could see that the link provided for the tts response shows the file type as raw instead of the wav file I get form Piper when I just do tts which does work
The issie appears to originate somewhere in home assistant since looking at the voice assistant logs shows the link having the raw extension on the file but it looks like the file type should be mp3 if I’m reading it correctly (the play audio button also doesn’t work)
I noticed that this seems to be an issue that others are having as well but I haven’t found any posts on it. Does anyone know if there is a way to fix this or if there is a permanent fix in the pipeline?
the form wouldn’t let me put this picture in my original post since I’m a new user so here it is
This may be related to #93528 and #92969
I was having this issue. Updating ESPHome to the latest dev version now gives an MP3 output, but the audio is unplayable. It seems like Piper is not currently capable of MP3 output.
