PIR activated Light brightness between certain hours
Would appreciate any help for this novice esphome user. Having trouble getting the below config to work to:
Turn on light full brightness between 5am & 7am and between 4pm & 9pm.
Turn on light 20% brightness between 9pm & 5am.
Off all other times.
Appreciate any tips :slight_smile:
esphome:
  friendly_name: Toilet Light
  platform: ESP8266
  board: d1_mini
  on_boot:
    priority: 600
    # turn on the light when powered on
    then:
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 70%
          blue: 45%
# Enable logging
logger:
# Enable Home Assistant API
api:
# Enable over the air updates
ota:
  platform: esphome
wifi:
  networks:
    - ssid: !secret 1_wifi_ssid
      password: !secret 1_wifi_password
    - ssid: !secret 2_wifi_ssid
      password: !secret 2_wifi_password
      manual_ip:
        static_ip: 192.168.0.231**strong text**
        gateway: 192.168.0.1
        subnet: 255.255.255.0
preferences:
  flash_write_interval: "48h"
time:
  - platform: sntp
  - platform: uptime
  - platform: dht
    pin: D2
    temperature:
      name: "Shower Vent Temperature"
    humidity:
      name: "Shower Vent Humidity"
    update_interval: 10s
    model: AM2302
  - platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
    update_interval: 60s
    entity_category: "diagnostic"
binary_sensor:
  - platform: gpio
    pin:
      number: D5
    device_class: motion
    filters:
      - delayed_on: 100ms
    on_press:
      then:
        - if:
            condition:
              or:
                - lambda: 'return id(toilet_time).now().hour >= 5 && id(toilet_time).now().hour < 8;'
                - lambda: 'return id(toilet_time).now().hour >= 16 && id(toilet_time).now().hour < 21;'
            then:
              - light.turn_on:
                  brightness: 100%
                  transition_length: 0.5s
        - if:
            condition:
              - lambda: 'return id(toilet_time).now().hour >= 21 && id(toilet_time).now().hour < 5;'
            then:
              - light.turn_on:
                  brightness: 20%
switch:
  - platform: restart
    name: "Toilet Light Reboot"
light:
  - platform: neopixelbus
    type: GRB
    variant: WS2812X
    pin: GPIO3
    num_leds: 20
    restore_mode: ALWAYS_ON
    default_transition_length: 10ms
    on_turn_on:
      then:
        - delay:
            minutes: 2
        - light.turn_off: toilet_light
How could hour be >21 and <5?
or might work better.
Not 100% sure, but I expect that hour is treated just as a number.
Have you looked at Blackies blueprint “Sensor Light” - it’s really powerful, does what you want and more. I use it in our main bathroom, hallway and pantry.
Hallway varies/switches by LUX, and 3x motion sensors, plus difference brightnesses and lamps for time variable. Bathroom varies by time, triggers by motion+presence sensors. Pantry is always the same, triggered by motion only.
Al have wirless bypass buttons on the wall too.
There is heaps of cool options built into it.
Thanks mate,
that’s done the trick! Such a “simple” one but just needed someones sound logic… lol
Cheers
