This template is not working anymore for me in 0.81.0… I have hue motion sensors. Seems to update only on HA restart… Am I the only one ?
EDIT: Solved ! Indeed, if you do not supply an entity_id in the configuration you will need to run the service homeassistant.update_entity to update the sensor.
Which PIR are you using? i am tired of using hue motion sensors, they work fine for walking into a room, but if i’m reading something for more then 30 minutes theres no motion…, well because there isn’t none, id much rather use PIR
if it used heat waves then it would detect that im sitting in my room and not turn off my lights automatically, i assumed heat waves used by PIR would detect someone and not turn off my lights
PIR needs motion of the heat producing item/body. They do use the tracking of heat but they require the heat to move across the IR beams. Thats why if you move slow enough (especially walking directly towards a PIR sensor) it wont detect you
you can get ‘presence detectors’ which are basically just high sensitivity motion sensors so that they can detect small movements such as someone working at a desk, or you can get heat detectors.
Perhaps your best option (rather than spending a lot of money) would simply to have a manual mode for your light so that it isn’t purely dependent on motion. I have my lights set up for 3 modes: ON, OFF and AUTO. AUTO is motion detection based. If I want the light to stay on without motion I simply put it in ON mode, likewise if I don’t want it to come on with motion I set it to OFF.
