Hi guys
I am using Aqara moving sensors with Home Assistant (zigbee2mqtt addon) which turn on/off the light and it is working fine when it that sensor have a “big” movement, but when you put it in the toilet or bathroom sometimes it does not pick up movement and light turn off. I think the best option here get a more sensitive ZigBee sensor or sensor that supports PIR (Passive infrared sensor) detection.
So the question is can someone recommend sensors which more sensitive than default Xiaomi/aqara sensors?
