PIR sensor and BME280 sensor makes HA crash!
As title.
Since I installed a PIR sensor and the BME280 I2C sensor HA chrome tab crash when I visit the history menu or even when I click on the pir sensor badge to show the history.
It seems that the chrome tab freezes and I need to close the tab…
Any idea on how to solve the problem?
It might help if you post your configuration for the PIR and BME280 sensors.
history_graph:
  smartostat_graph_furnance:
    name: Smartostat grafico caldaia
    entities:
      - switch.room_furnace
    hours_to_show: 24
    refresh: 10
  smartostat_graph_temp:
    name: Smartostat grafico temperatura
    entities:
      - sensor.room_temp
    hours_to_show: 24
    refresh: 10
  smartostat_graph_humidity:
    name: Smartostat grafico umidita
    entities:
      - sensor.room_humidity
    hours_to_show: 12
    refresh: 30
  smartostat_graph_pressure:
    name: Smartostat grafico pressione
    entities:
      - sensor.room_pressure
    hours_to_show: 12
    refresh: 30
  smartostat_graph_pir:
    name: Smartostat grafico presenze
    entities:
      - binary_sensor.sr501pir
    hours_to_show: 12
    refresh: 30
  rasp_cpu_temp:
    entities:
      - sensor.raspberry_cpu_temp
      - sensor.processor_use
      - sensor.disk_use_percent_home
      - sensor.memory_free
    hours_to_show: 12
    refresh: 10
done
Please read the blue banner at the top of the page and format your code.
done tom formatted, please help
That’s the config for your history graphs. It looks fine. Post the code for your sensors set up.
Also do you have any of the sensors excluded from either the recorder or history?
# Sensors
  - platform: command_line
    name: Raspberry CPU Temp
    command: "cat /sys/class/thermal/thermal_zone0/temp"
    unit_of_measurement: "°C"
    value_template: '{{ value | multiply(0.001) | round(1) }}'
  - platform: systemmonitor
    resources:
      - type: disk_use_percent
        arg: /home
      - type: memory_free
      - type: memory_use
      - type: processor_use
      - type: network_in
        arg: eth0
      - type: network_out
        arg: eth0
      - type: last_boot
  - platform: mqtt
    state_topic: 'tele/smartostat/SENSOR'
    name: 'Room Temp' #BME280
    unit_of_measurement: '°C'
    value_template: '{{ value_json.BME280.Temperature }}'
    retain: false
  - platform: mqtt
    name: 'Room Humidity'
    unit_of_measurement: '%'
    value_template: '{{ value_json.BME280.Humidity }}'
    retain: false
  - platform: mqtt
    name: 'Room Pressure'
    unit_of_measurement: 'hPa'
    value_template: '{{ value_json.BME280.Pressure }}'
    retain: false
  - platform: min_max
    name: "Average Room Temp"
    type: "mean"
    round_digits: 1
    entity_ids:
      - sensor.room_temp
no exclusion in the recorder neither in history
Binary sensor config too.
binary_sensor:
  - platform: mqtt
    state_topic: "stat/smartostat/POWER2"
How frequently are these sensors updated - I mean how frequently are messages sent?
There’s nothing wrong with your config.
One thing you could try is to delete your home-assistant_v2.db and restart (so it is recreated). This will delete any history you have but it may solve the problem. It’s a shotgun approach - close your eyes, pull the trigger and hope you hit something - but it’s all I’ve got.
Sincerely don’t know
Done it. It solves the problem for 24 hours than the log became big again and the problem reappear
