to my sensors.yaml
geting next message when checking my configuration:
Invalid config for [sensor.mqtt]: [payload_on] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->payload_on. (See ?, line ?).
I need some more help if possible…
it’s my first time to use ESPhome, I’m trying to follow the above guide, I don’t understand what are the steps for configuring the Wemos D1 Mini ESP8266 chip
thank you
thank you so much I really appreciate!
my problem is not yet with the configuration
but with flashing the ESPhome
I don’t understand what are the steps needed for
A. flashing itself
B. configure the D1 Mini as shown in the guide
C. connecting to HA
Yes I did, ok, I understand how to flash the basic bin file on the Wemos D1 but after that how do I configure it as shown at the guide and how do I add it to HA without erasing that configuration
sorry trying to explain:
A. I installed ESPHOME
B. I can see the Wemos D1
C. I changed his wifi to my home wifi
D. how do I change the configuration of the “pin1 and the other pin”
E. how do i change the Mqtt for the Wemos D1
Then flash it to the Wemos.
Concerning MQTT, I think you shouldn’t do anything if you have it already enabled in HomeAssistant; it will autodiscovery the node.
Sorry. I haven’t had this issue in the past. Not sure how to guide you through this. Probably it is a good idea to open a new post in the ESPhome subforum with that error message in the title and provide as much information as possible: HA instalation method, system info, device yaml file in ESPhome, logs from the device in ESPhome, logs from HA.
Good luck!
