PIR Sensors and a D1 Mini
Hey all
I have connected all the exisiting PIR Sensors to a D1 mini that publishes to mqtt when motion is detected. I have one small problem though, it keeps disconnecting after a while and then I have to go and pull out the USB cable from the D1 and put it back to restart.
Please see my code below, any help will be appreciated! Please excuse the way the code looks, I can’t seem to fix it
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#define WLAN_SSID “HAWIFI”
#define WLAN_PASS “wifipasswd”
WiFiClient client;
PubSubClient mqtt(client, “192.168.0.1”, 1883);
#define SENSOR_COUNT 7
#define DEVICE_NAME “pirsensors”
byte sensorPins[SENSOR_COUNT] = {D1, D2, D3, D4, D5, D6, D7}; // The pins to which the sensors are connected.
boolean sensorStates[SENSOR_COUNT] = {1, 1, 1, 1, 1, 1, 1};
String deviceName = DEVICE_NAME;
String sensorNames[SENSOR_COUNT] = {“MasterBedroom”,“GamingRoom”,“Hallway”,“SpareBedroom”,“Lounge”,“Office”,“Laundry”};
void setup() {
// the the pinmode for all used pins to INPUT_PULLUP
for (byte i = 0; i < SENSOR_COUNT; i++) {
    byte pin = sensorPins[i];
    pinMode(pin, INPUT_PULLUP);
// Initiate the serial connection for debugging.
Serial.begin(115200);
delay(10);
Serial.println("Starting ...");
void loop() {
// Check if the Wifi is connected, if not, call the WiFi_connect() method.
if (WiFi.status() != WL_CONNECTED) {
    WiFi_connect();
// Check if there is a connection with the MQTT server, if not, call the MQTT_connect() method.
if (!mqtt.connected()) {
    Serial.println("MQTT Disconnected!");
    MQTT_connect();
// Call the loop method, to periodically ping the server to keep the connection alive.
mqtt.loop();
// Loop thru all the sensors defined at the start.
    // Create some helper variables.
    boolean pinState = digitalRead(pin);
    boolean lastPinState =  sensorStates[i];
    String sensorName = sensorNames[i];
    // Check if the state for the current pin has changed.
    if (pinState != lastPinState) {
        // Define a string with the topic to which we want to post the new state to ...
        // and convert it into a char * array which we need for the pubsubclient.
        String feedNameString =  String("/Home/PIRSensors/" + sensorName);
        char topic[feedNameString.length() + 1];
        feedNameString.toCharArray(topic, feedNameString.length() + 1);
        // Output the new state to the serial for debugging.
        Serial.print("New state for sensor ");
        Serial.print(topic);
        Serial.print(": ");
        Serial.print(pinState);
        // Publish the new state to the MQTT server.
        // The message is sent as a retained message to always
        // have the last state available on the broker.
        // The QoS is set to 1, to make sure the delivery
        // of the mseeage to the broker is guaranteed.
        if (mqtt.publish(MQTT::Publish(topic, pinState ? "Triggered" : "Idle").set_retain().set_qos(1).set_dup())) {
            Serial.println(F(" ... Published!"));
        } else {
            Serial.println(F(" ... MQTT PUBLISH FAILED!"));
        // Store the new pinstate in the pinStates array.
        sensorStates[i] = pinState;
// Wait 50 miliseconds before we repeat the runloop.
delay(50);
void WiFi_connect() {
// Print some debuggin info to the serial terminal.
Serial.println(); Serial.println();
Serial.print("Connecting to “);
Serial.print(WLAN_SSID);
Serial.print(” ");
// Connect to the WiFi netwerk using the previously defined SSID and Password.
WiFi.begin(WLAN_SSID, WLAN_PASS);
while (WiFi.status() != WL_CONNECTED) {
    // If there is no connection. Wait half a second before checking again.
    delay(500);
    Serial.print(".");
Serial.println();
// After the connection is established, print the IP-adres to the serial terminal for debugging.
Serial.print("WiFi connected! - ");
Serial.print("IP address: ");
Serial.println(WiFi.localIP());
void MQTT_connect() {
// Define a string with the topic to which we want to post the connection state of this device to …
String feedNameString = String("/Home/PIRSensors/connection");
// As long as there is no active MQTT connection ...
while (!mqtt.connected()) {
    Serial.print("Attempting MQTT connection ... ");
    // Try to connect to the MQTT broker.
    // As the 'will' we set the topic and connection state to 0.
    // This means that is if the connection is dropped,
    // the broker will publish the connection state to the defined topic.
    if (mqtt.connect(MQTT::Connect(DEVICE_NAME).set_will(topic, "0", 1, true))) {
        Serial.println("Connected!");
        // After the connection is established, publish a new connection state.
        mqtt.publish(MQTT::Publish(topic, "1").set_retain().set_qos(1));
    } else {
        // Wait half a second before trying again.
        Serial.println("Failed! - Try again in half a second.");
        delay(500);
Seems to be a problem with the usb port on the board.
Will keep testing
Does it disconnect from the wifi, or from the MQTT broker?
Seems it just dies and then restarts. Looks like a problem with the usb port on the board.
With that many sensors I would check how much current is being drawn through the USB, under certain scenarios you may be going over the USB chip limit, this would cause it to shut down, power reset would reset thermal fuse, try powering through pins to bypass USB chipset, but first find out current limitations of the board you have.
