Pixel Watch 2 sensors update not working
I’m using a Pixel Watch 2 since a few days and enabled the heart rate and pressure sensors within the app on the watch. However HA only receives updates for the heart rate & pressure sensors when the app on the watch is opened. The battery level however gets updated frequently (~15mins interval). Ofc I’ve allowed to read these two sensors in the background (set to “always”). What else is needed to get it to work properly? Oh almost forgot, when sending a “command_update_sensors” from my HA, it sometimes does get the current values. If it’s important, my Pixel Watch 2 is connected to a OnePlus 7T, where the companion app of HA is installed.
Exact same issue on another Pixel Watch 2 connected to a Google Pixel 8 :thinking:
Did you have any luck with this? Same issue here. Have been troubleshooting to no avail yet.
Not really, sometimes it works, sometimes it doesn’t. Seems to update but not frequently.
Thanks for the reply. Haven’t gotten anywhere yet but I’m tinkering, will bump this when I have more info. Cheers endy
Thank you, much appreciated! Will post as well when I have any news.
Did you guys find a solution? I have exactly the same issue. Battery level updates very frequent heart rate extremely rarely.
Any news? I can confirm Diagnostic data get updated regularly. Sensor data will only updated if I open the app.
// add
Just realized bed mode isn’t updated too. I guess the only entity which is really getting updated regularly is battery level and charging state
