Found some time to look into this, if anyone interested, see below. Feel free to suggest improvements, still trying out myself…
- Install Pixometer app to easily scan your meter reading with smartphone camera
- Add your Pixometer credentials in json payload format into your
secrets.yaml
, should look like: pixometer_credentials: '{ "username" : "[email protected]", "password": "XXXXXXXXXXXXX" }'
- Navigate to https://pixometer.io/portal/#/login to login on the API website
- Navigate to https://pixometer.io/api/v1/meters/ to get your meter_id values
- Repeat below rest readings configuration for every meter you’d like to use adding the correct
meter_id
into the rest resource url
configuration.yaml
- platform: rest
method: POST
resource: https://pixometer.io/api/v1/access-token/
payload: !secret pixometer_credentials
scan_interval: 3600
value_template: '{{"Bearer "+ value_json.access_token}}'
headers:
Content-Type: application/json
- platform: rest
name: Pixometer Electricity
resource: https://pixometer.io/api/v1/readings/?meter_id=XXXXXXXX&o=-created
headers:
Authorization: '{{states("sensor.pixometer_token")}}'
json_attributes:
- results
value_template: "{{ value_json.results[0].value }}"
sensors:
electricity_pixometer:
value_template: "{{ states.sensor.pixometer_electricity.attributes.results[0].value }}"
device_class: energy
unit_of_measurement: "kWh"
utility_meter:
energy:
source: sensor.electricity_pixometer
cycle: daily
net_consumption: true
Updated my post to automatically fetch the access token with a separate rest sensor ‘Pixometer Token’, as this access token has limited time to live.
