Planning and setup - ESP32-S3 - 4848S040 - 480*480 IPS touchscreen
thanks. now is working
Please post your yaml properly.
I tried adding a background image, but the image covers all the labels and text, how can I position the image at the bottom without blocking the buttons and labels. I used the following example, please correct it.
{“page”:1,“id”:34,“obj”:“img”,“src”:“L:/image.png”,“auto_size”:0,“w”:400}
There is a command in the docs, but I haven’t tried it:
p1b34.to_back
What I have found through experimenting is that the objects are layered in their order in the pages.jsonl file. (NOT the “id”: number.)
In this first example, the larger button onject is in the jsonl file before the smaller label object.
  "page":3,"id":1,"obj":"btn","x":120,"y":0,"w":240,"h":240,"bg_color": "red","text":"This is Page 3","align":2,"value_font":22,"text_color":"gray","radius":0,"border_side":0
  "page":3,"id":2,"obj":"label","x":150,"y":200,"w":200,"h":100,"text":"#0000FF \uE64A# #FF0000 Hello# #FFFFFF world#!"
Resulting in:
1
In the second example, the smaller label is in the file before the larger button object, and thus covered:
Result:
2
Where is this background gradient defined?
  "page":3,"id":1,"obj":"btn","x":120,"y":0,"w":240,"h":240,"bg_color": "red","text_color":"gray","text":"This is a big button","align":2,"value_font":22,"radius":0,"border_side":0
bigbutton
Found it:
thank you @stevemann
I’m really still a beginner, seeing a display like this, I feel amazed and enthusiastic about learning, where should I start to get a display like the one above. Thank you
you say In the folder “custom_templates” add a new file: openhasp.jinja. My question is where is the location of the “custom_templates” folder, is this folder created in the folder
/homeassistant/custom_components/openhasp ?Please enlighten me. Thank you
Just create it. It will be there if you have other custom templates defined. Otherwise, mkdir is your friend.
thank you i will try it
I’ve tried it but nothing changes with the display. Where is my error?
Just to be sure, the path the the file your created should be
/config/custom_templates/openhasp.jinja
my mine is :/homeassistant/custom_components/openhasp/custom_templates/openhasp.jinja
Wrong, assuming your configuration.yaml is in /home assistant, then the correct path is /homeassistant/custom_templates/openhasp.jinja.
I thought it was placed in the open hasp folder. OK, I’ll try again
here is my configuration.yaml:
homeassistant:
  allowlist_external_dirs:
    - "/config/openhasp"
openhasp:
  home:
     objects:
      # SEITE 0
      - obj: "p0b0" # SETTINGS
        properties:
          "bg_color" : "{% from 'openhasp.jinja' import color %}{{color('bg')}}"
      - obj: "p0b1" # PREVIOUS - BUTTON"
        properties:
          "w": "{% import 'openhasp.jinja' as grid %}{{grid.w(4)}}"
          "h": "{% import 'openhasp.jinja' as grid %}{{grid.h(2)}}"
          "x": "{% import 'openhasp.jinja' as grid %}{{grid.x(1)}}"
          "y": "{% import 'openhasp.jinja' as grid %}{{grid.y(11)}}"
          "text": "\uE04D"
          "radius": "{% from 'openhasp.jinja' import grid %} {{(grid() | from_json).radius |int}}"
          "bg_color": "{% from 'openhasp.jinja' import color %}{{color('primary')}}"
          "bg_color02": "{% from 'openhasp.jinja' import color %}{{color('primary_light')}}"
      - obj: "p0b2" # HOME - BUTTON
        properties:
          "x": "{% import 'openhasp.jinja' as grid %}{{grid.x(5)}}"
          "text": "\uE6A1"
      - obj: "p0b3" # NEXT - BUTTON
        properties:
          "x": "{% import 'openhasp.jinja' as grid %}{{grid.x(9)}}"
          "text": "\uE054"
      # SEITE 1
      - obj: "p1b0" # SETTINGS
        properties:
      - obj: "p1b2" # CONTAINER
        properties:
          "w": "{% from 'openhasp.jinja' import grid %} {{(grid() | from_json).display_width}}"
          "h": "{% import 'openhasp.jinja' as grid %}{{grid.h(10)}}"
          "x": 0
          "y": 0
template:
  - binary_sensor:
    - name: Display settings
      unique_id: 1b3a3dae-fd0c-4f47-9c8b-5b680478a977 # https://www.uuidgenerator.net/
      state: "{{ now() - state_attr(this.attributes.update_automation | default('automation.update_display_data'), 'last_triggered') > timedelta(seconds=this.attributes.update_time | default(120) |int ) }}" # change the default automation entity_id from step 3 before
      delay_on:
        seconds: 2
      attributes:
        update_automation: "automation.update_display_data" # add a the automation entity_id from step 3 before
        update_time: "80" # sending the config via mqtt needs some time to complete. This stops the automation from re.run before sending config is finished
        display_w: "480"
        display_h: "480"
        grid_cols: "12" # increase for more resolution of object
        grid_rows: "12" # increase for more resolution of object
        grid_gutter: "8" # This looked nice for me
        grid_margin: "4" # This looked nice for me
        bg_color: "#000000"
        primary_color: "#4193d5"
        secondary_color: "#ee9f52"
        accent_color: "#A175C4"
        success_color: "#6cbe58"
        warning_color: "#d67430"
        error_color: "#e25628"
        radius: "4"
Next, the location of openhasp.jinja is /homeassistant/custom_templates/openhasp.jinja. Then the location of page.jason is /homeassistant/openhasp/pages.json, but no display appears. please enlighten me.
The layout goes here: (under configuration) not at the display
Open your Home Assistant instance and show an integration.
I have tried it and the result is that only 1 button appears as shown in the attached picture. Here are the contents of the pages.jason file whose path is /config/openhasp/pages.json:
    "SEITE 0 - SETTINGS",
        "page": 1,
        "id": 0,
        "prev": 4
    "SEITE 0 - PREVIOUS -BUTTON",
        "page": 0,
        "id": 1,
        "obj": "btn",
        "outline_opa": 0,
        "border_opa": 0,
        "text_font": 32,
        "toggle": false,
        "action": "prev"
    "SEITE 0 - HOME - BUTTON",
        "page": 0,
        "id": 2,
        "obj": "btn",
        "outline_opa": 0,
        "border_opa": 0,
        "text_font": 32,
        "toggle": false,
        "action": {
            "down": "back",
            "hold": "restart"
    "SEITE 0 - NEXT - BUTTON",
        "page": 0,
        "id": 3,
        "obj": "btn",
        "text": "\uE054",
        "outline_opa": 0,
        "border_opa": 0,
        "text_font": 32,
        "action": "next",
        "toggle": false
    "SEITE 1 - CONTAINER",
        "page": 1,
        "id": 2,
        "obj": "obj",
        "border_opa": 0,
        "bg_opa": 0,
        "click": 0
.please enlighten me
I am confused. Easily done since I am just learning to code openHasp.
Preferring to keep things simple, I have not ventured into using templates or other fancy programmer tools.
Can we rewind to the beginning? On a piece of paper, draw what you want to see on the screen. Post that here.
