Hi, is there any way I can specify a start date to how many weeks and get an end date. In addition, in a Lovelace the start date is displayed to me as well as the end date and in which week we are. In addition, the necessary environment values that I have prefabricated.
For example, Veg: Co2: Day 30C and night 22 degrees or if you select without Co2: Day 28 degrees and night 22 degrees. 800 PPF Light and Co2 1200 PPM, VPD 0.8
Bloom:
Bloom Week 1-3 : Co2: Day 30C and Night 20 degrees or if you select without Co2 : Day 28 degrees and Night 20 degrees 1250 PPF Light and Co2 1200 PPM , VPD 1.0
Last 2 Weeks : Co2: Day 26C and night 19 degrees or if you select without 1000 PPF Light , VPD 1.2
between 1-3 weeks and the Last 2 Weeks : it would be 26 degrees and night 22 degrees 1250 PPF Light , VPD 1.1
So if I can select the start date, in which phase we are and accordingly the information about the current phase should be displayed.
For example, I have a map in the dashboard that shows me the temperature and humidity of the room and other sensor data. I would then want to see the information immediately.
In addition, the question would be but that I am not so important whether it would be possible to get a bar in it to show me the current status shows in which week I am. between start and current period it should be green and from the current period to the end date green and the current period should be a black line.
Many greetings and thanks
Translated with DeepL Translate: The world's most accurate translator (free version)
