Plant moisture notification
This is based off the great “Low Battery Level Detection” blueprint by Sbyx. This Blueprint works using the data in the “plant” card, you need to have min_moisture setup for your plants in order for this to work. I personally use Mi Flora sensors and a Bluetooth dongle on a raspberrypi (not the same Pi that HASS runs on). I make use of the following package to relay the data to HASS via MQTT (GitHub - ThomDietrich/miflora-mqtt-daemon: Linux service to collect and transfer Xiaomi Mi Flora plant sensor data via MQTT to your smart home system, with cluster support 🌱🌼🥀🏡🌳).
Here is my action notification yaml I have configured:
service: notify.mobile_app_my_phone
  message: 'Low moisture warning for: {{sensors}}'
Here are some of my plants :smiley:
Let me know if you run into any issues. Also of note, Bluetooth does not seem to work well through glass windows, especially for the Mi Flora sensors. Just keep this in mind if you have your Bluetooth dongle inside (near a window) and plants outside. Good luck!
blueprint:
  name: Low moisture level detection & notification for all plant sensors
  description: Regularly test all plant sensors with 'moisture' crossing
    under their threshold.
  domain: automation
  input:
    time:
      name: Time to test on
      description: Test is run at configured time
      default: '10:00:00'
      selector:
        time: {}
    day:
      name: Weekday to test on
      description: 'Test is run at configured time either everyday (0) or on a given
        weekday (1: Monday ... 7: Sunday)'
      default: 0
      selector:
        number:
          min: 0.0
          max: 7.0
          mode: slider
          step: 1.0
    exclude:
      description: Plant sensors (e.g. cactus) to exclude from detection. Only entities are supported, devices must be expanded!
      default: {entity_id: []}
      selector:
          entity:
            domain: plant
    actions:
      description: Notifications or similar to be run. {{sensors}} is replaced with
        the names of sensors being low on moisture.
      selector:
        action: {}
variables:
  day: !input 'day'
  exclude: !input 'exclude'
  sensors: >-
    {% set result = namespace(sensors=[]) %}
    {% for state in states.plant if 'moisture low' in state.attributes.problem %}
      {% if not state.entity_id in exclude.entity_id %}
        {% set result.sensors = result.sensors + [state.attributes.friendly_name] %}
      {% endif %}
    {% endfor %}
    {{result.sensors|join(', ')}}
- platform: time
  at: !input 'time'
condition:
- '{{ sensors != '''' and (day | int == 0 or day | int == now().isoweekday()) }}'
- choose: []
  default: !input 'actions'
mode: single
@cweakland, Thank you so much. I have implemented this, hopefully it works as intended. Do you have any updates on this blueprint?
Any chance to get the friendly name of the plant sensors to be used in actions such as mobile app notification or alexa media player announcement?
  message: 'Low moisture warning for: {{sensors}}' <-- Frindly name of sensors
I don’t have friendly names set on my plants, however, I think you would change state.name with state.attributes.friendly_name. I will test this out later on and let you know if it works, if it does, I will update the blueprint.
Edit: It worked. I updated the blueprint, you will have to re-download it.
It seems like state.attributes.friendly_name is same as state.name for plant entities.
Tried this in template editor:
{% set result = namespace( sensors = [] ) %}
{% endfor %}
But when I try to declare a friendly_name in <config>/plants.yaml config file I get a configuration error.
@cweakland, And is there any chance that you can make the plant sensors template logic into a binary_sensor like below, so that if any plant has moisture low then that state can be used to set the state of binary_sensor to on which in-turn can be used as a trigger in mobile_app or mediaplayer notification automation.
template:
  - binary_sensor:
      - name: People home
        state: >
          {{ is_state('device_tracker.sean', 'home')
             or is_state('binary_sensor.hallway_134', 'on') }}
Friendly name has to be set in customize.yaml.
I have even tried customize.yaml long ago and I get a config error for that as well.
Error:
extra keys not allowed @ data['customize']['ficus_elastica']
cusotmize.yaml
# Plants
plant.dypsis_lutescens:
  friendly_name: Dypsis Lutescens
ficus_elastica:
  friendly_name: Ficus Elastica
EDIT
Now I realized my silly mistake in customize.yaml. Fixed and now that works. Thank you for making me revisit this issue.
# Plants
plant.ficus_elastica:
@cweakland, I was able to convert the template logic in your blueprint to a binary_sensor like how I asked for in this post:
# plant low moisture sensor
- binary_sensor:
    - name: Thirsty Plants
      state: >
        {% set thirsty = namespace( plants = []) %}
        {% set allplants = states.plant %}
        {% for plant in allplants if 'moisture low' in plant.attributes.problem %}
            {% set thirsty.plants = thirsty.plants + [plant.name] %}
        {% endfor %}
        {{ thirsty.plants|length > 0 }}
@cweakland Can you let me know which plant card you are using and how you are showing up the image of the plant in the card. Thanks
I believe it is the built in “plant status” card. Then I went on google, searched for an image I liked, download it, cropped it some, and tied it in via customize.yaml like so:
plant.monstera:
  friendly_name: Monstera
  entity_picture: /local/plants/monstera.jpg
The actual file resides here: /root/config/www/plants/monstera.jpg
@cweakland Thank you so much, I am also using the built in plant card but entity_picture is something I didn’t know about before. It made me revisit customizing entities documentation. Thanks again.
Thank you very much! I am not used to importing blueprints without a github-url, so I created one myself. Please advice if this is stupid :smiley:
For anyone who’d like to simply import this:
As action I also included the option to open the corresponding dashboard (action field after you import the blueprint and clicked on “create”):
service: notify.mobile_app_al_13_app
  message: "Low moisture warning for: {{sensors}}"
    actions:
      - action: URI
        title: App öffnen
        uri: /lovelace-zimmer/plants
        icon: mdi:home-assistant
That’s fine, I have had success entering this URL into the Blueprint addition tool in HA and it performs the import.
I tried to change your blueprint, since my moisture alert is resulting “low” status, but it does not work:
  sensors: >-
           {% for state in states.plant if 'Low' in state.attributes.moisture_status %}
             {% endif %}
           {% endfor %}
This always results in the error:
“TypeError: argument of type ‘NoneType’ is not iterable”
What’s the problem?
I have the same problem myself. Did you figure it out?
I have a feeling that one of your sensors is reporting ‘unknown’ in the moisture status as mine is but I can’t figure out how to filter this out
{% set result = namespace( sensors = [  ] ) %}
{% for state in states.plant if 'Low' in state.attributes.conductivity_status | rejectattr("null") %}
{% endfor %}
{{result.sensors|join(', ') }}
If I put a filter in where I think it should go it fails with
‘str object’ has no value “null”
I know it works fine on a system with no ‘null’ attributes.
Is it possible to run this automation every hour?
Today i was renovating my plant sensor setup.
And i thought isn't nice to have a Notify Blueprint for notify me when my plants are in bad mood.
So i stumbled over this old threat with a none working blueprint.
so i ask claude ai to get it right. and guess what?
Now it works for me.
Claude AI code below:
blueprint:
  description: Regularly check all plants for low moisture or conductivity (Needs
    to be used with Plant Monitor integration)
  domain: automation
  input:
    device:
      description: Pick one or more devices to send the notification to
      selector:
        device:
          integration: mobile_app
          multiple: true
    time:
      name: Time to check
      default: '20:00:00'
      selector:
        time: {}
    day:
      name: Weekday to check
      description: Check is run at configured time either everyday or on a given weekday
      selector:
        select:
          options:
          - label: jeden tag
            value: '0'
          - label: Monday
            value: '1'
          - label: Tuesday
            value: '2'
          - label: Wednesday
            value: '3'
          - label: Thursday
            value: '4'
          - label: Friday
            value: '5'
          - label: Saturday
            value: '6'
          - label: Sunday
            value: '7'
          custom_value: false
          multiple: false
      default: '0'
    exclude:
      description: Plants to exclude from detection. Only entities are supported,
      default:
        entity_id: []
      selector:
          entity:
            device_class: plant
    water_text:
      description: Text to display as title for the sensors with low moisture
      selector:
        text:
          type: text
          multiline: false
      default: 'Needs water:'
    nutritions_text:
      description: Text to display as title for the sensors with low nutritions
      selector:
        text:
          type: text
          multiline: false
      default: 'Needs nutrition:'
    both_text:
      description: Text to display as title for the sensors with low nutritions &
        water
      selector:
        text:
          type: text
          multiline: false
      default: 'Needs water & nutrition:'
    high_temp_enabled:
      name: High temp alarm
      description: Turn on to activate a high temp alarm at the set temperature.
      selector:
        boolean: {}
      default: false
    low_temp_enabled:
      name: Low temp alarm
      description: Turn on to activate a low temp alarm at the set temperature.
      selector:
        boolean: {}
      default: false
    night_temp_enabled:
      name: Night temp alarm
      description: "Turn on to activate an alarm when the temperature in the next
        12 hours will fall below the low treshold.\nUsefull for when you have plants
        outside that can't handle cold weather that well. \n\nRemember to turn this
        off incase you bring your plants inside for the winter"
      selector:
        boolean: {}
      default: false
    hourly_weather_forcast:
      description: "The hourly weather sensor you want to use for the night notification,
        \n Requires Met.no (the standard integration in HA) and home houerly sensor
        needs to be activated"
      selector:
        entity:
          domain: weather
          multiple: false
    temp_sensor:
      description: Choose the temperature sensor to use for the temp alarms.
      selector:
        entity:
          device_class: temperature
          domain: sensor
          multiple: false
    high_threshold:
      name: High temp level threshold
      description: "Treshhold for high temp alarm, \n if the specified sensor is above this value then you will get a notification."
      default: 35
      selector:
        number:
          min: 0.0
          max: 100.0
          unit_of_measurement: °C
          mode: slider
          step: 1.0
    low_threshold:
      name: Low temp level threshold
      description: "Treshhold for low temp alarm, \n if the specified sensor is above this value then you will get a notification."
      default: 8
      selector:
        number:
          min: 0.0
          max: 100.0
          mode: slider
          step: 1.0
    persistent:
      name: Persistent & actionable
      description: turn this on if you want a persistent and actionable notification
      selector:
        boolean: {}
      default: false
    channel:
      description: "The channel to use for the persistant notification, \nthis is usefull if you want a diffrent notification sound on your mobile device."
      selector:
        text:
          multiline: false
      default: General
    alexa_enabled:
      name: Enable Alexa announcement
      description: Turn on to also send plant/temp alerts as an Alexa announcement.
      selector:
        boolean: {}
      default: false
    alexa_targets:
      name: Alexa device(s)
      description: "Pick one or more Alexa media_player entities to announce on.\n Requires the Alexa Media Player integration (HACS)."
      default: []
      selector:
        entity:
          integration: alexa_media
          domain: media_player
          multiple: true
    alexa_volume:
      name: Alexa announcement volume
      description: Volume level for the Alexa announcement (0.0 – 1.0). Leave at 0 to keep the current volume.
      default: 0.5
      selector:
        number:
          min: 0.0
          max: 1.0
          step: 0.05
          mode: slider
    action_1:
      description: "Action to be run when you get the notification. \nAs an example run a script or turn on a lamp"
      selector:
        action: {}
      default: []
    action_1_status:
      name: Run First action when the plants have a problem
      description: turn this on if you want to run First action when the plants have
        a problem
      selector:
        boolean: {}
      default: false
    action_1_high:
      name: Run First action when the temperature high triggers
      description: turn this on if you want to run First action when the temperature
        high triggers
      selector:
        boolean: {}
      default: false
    action_1_low:
      name: Run First action when the temperature low triggers
        low triggers
      selector:
        boolean: {}
      default: false
    action_2:
      description: "Action to be run when you push the button before the notification
        is cleared. \nAs an example turn on a script or an input_bool."
      selector:
        action: {}
      default: []
    action_2_active:
      name: Enable the second action
      description: Turn this on if you want to activate the Second action
      selector:
        boolean: {}
      default: false
    action_3:
      description: "Action to be run after the notification is cleared. \nAs an example wait for a script to finish or turn off the input_bool from
        the Second action"
      selector:
        action: {}
      default: []
    action_3_active:
      description: Turn this on if you want to activate the Third action
      selector:
        boolean: {}
      default: false
  source_url: https://github.com/H0W2D017/HA_Flower_Blueprint/blob/main/Flowers.yaml
variables:
  device: !input device
  day: !input day
  exclude: !input exclude
  temp_sensor: !input temp_sensor
  high_threshold: !input high_threshold
  low_threshold: !input low_threshold
  forecast: !input hourly_weather_forcast
  persistent: !input persistent
  channel: !input channel
  action_1: !input action_1
  night_temp_enabled: !input night_temp_enabled
  nutritions_text: !input nutritions_text
  water_text: !input water_text
  both_text: !input both_text
  alexa_enabled: !input alexa_enabled
  alexa_targets: !input alexa_targets
  alexa_volume: !input alexa_volume
  sensors: >
        | selectattr("attributes.device_class", "==", "plant")
        | selectattr("state", "==", "problem")
        | selectattr("attributes.moisture_status", "!=", "High")
        | selectattr("attributes.conductivity_status", "!=", "High") %}
      {% set result.sensors = result.sensors + [state.name] %}
    {% endfor %}
    {{ result.sensors | join(", ") }}
  water: >
        | selectattr("attributes.moisture_status", "defined")
        | selectattr("attributes.moisture_status", "==", "Low")
        | selectattr("attributes.conductivity_status", "==", "ok") %}
    {% endfor %}
    {% if result.sensors | join(",") != "" %}
      {{ water_text + "\n" + result.sensors | join(",\n") }}
    {% endif %}
  nutritions: >
        | selectattr("attributes.moisture_status", "==", "ok")
        | selectattr("attributes.conductivity_status", "==", "Low") %}
    {% endfor %}
      {{ nutritions_text + "\n" + result.sensors | join(",\n") }}
    {% endif %}
  both: >
    {% endfor %}
      {{ both_text + "\n" + result.sensors | join(",\n") }}
    {% endif %}
# The triggers for the automation
  - platform: time
    at: !input time
  - platform: numeric_state
    entity_id: !input temp_sensor
    above: !input high_threshold
    for:
      hours: 1
      minutes: 0
      seconds: 0
    below: !input low_threshold
    for:
      hours: 0
      minutes: 15
      seconds: 0
  - choose:
      # ── Status notification ────────────────────────────────────────────────
      - conditions:
          - condition: trigger
          # FIX: OR condition — night_temp branch only evaluates after get_forecasts runs,
          # so we guard here with night_temp_enabled; the actual temp check happens in sequence.
          - condition: or
            conditions:
              - '{{ sensors != "" and (day | int == 0 or day | int == now().isoweekday()) }}'
              - '{{ night_temp_enabled == true }}'
        sequence:
          # Fetch the hourly forecast properly via weather.get_forecasts (HA 2024.x+)
          - action: weather.get_forecasts
              entity_id: !input hourly_weather_forcast
              type: hourly
            response_variable: forecast_response
          # Derive lowest temp over the next 12 hours from the service response
          - variables:
              lowest_night_temp: >
                {% set fc = forecast_response[forecast].forecast %}
                {% if fc is not none and fc | length >= 14 %}
                  {{ [fc[0].temperature,  fc[1].temperature,  fc[2].temperature,
                      fc[3].temperature,  fc[4].temperature,  fc[5].temperature,
                      fc[6].temperature,  fc[7].temperature,  fc[8].temperature,
                      fc[9].temperature,  fc[10].temperature, fc[11].temperature,
                      fc[12].temperature, fc[13].temperature] | min }}
                {% else %}
                  999
                {% endif %}
              night_temp: >
                {% if lowest_night_temp | float(999) < low_threshold | float and night_temp_enabled == true %}
                  The temperature will be below {{ low_threshold | int }}°C, and at its lowest point it will be {{ lowest_night_temp }}°C
                {% endif %}
          - parallel:
              # ── Mobile notifications (one per device) ──────────────────────
              - repeat:
                  for_each: '{{ device if device is iterable and device is not string else [device] }}'
                  sequence:
                    - action: >-
                        notify.mobile_app_{{ device_attr(repeat.item, 'name')
                        | lower | replace(" ", "_") }}
                        message: >-
                          {% if water != "" %}{{ water }}{% endif -%}
                          {% if nutritions != "" %}\n\n{{ nutritions }}{% endif -%}
                          {% if both != "" %}\n\n{{ both }}{% endif -%}
                          {% if night_temp is defined and night_temp != "" %}\n\n{{ night_temp }}{% endif -%}
                        title: '{{ sensors }}'
                          tag: '{% if persistent == true %}flowerpower{% endif %}'
                          persistent: '{{ persistent }}'
                          sticky: '{{ persistent }}'
                          channel: '{{ channel }}'
                          actions:
                            - action: '{% if persistent == true %}"action_open"{% endif %}'
                              title: '{% if persistent == true %}ok{% endif %}'
              # ── Alexa announcement ─────────────────────────────────────────
              - if:
                  - condition: template
                    value_template: '{{ alexa_enabled == true and alexa_targets | length > 0 }}'
                then:
                  - action: media_player.volume_set
                      entity_id: '{{ alexa_targets }}'
                      volume_level: '{{ alexa_volume }}'
                  - action: notify.alexa_media
                      target: '{{ alexa_targets }}'
                      message: >-
                        {% set parts = namespace(items=[]) %}
                          {% set clean = water | replace(water_text, "") | replace("\n", " ") | replace(":", "") | trim %}
                          {% set parts.items = parts.items + ["Pflanzen die Wasser brauchen: " + clean] %}
                        {% endif %}
                          {% set clean = nutritions | replace(nutritions_text, "") | replace("\n", " ") | replace(":", "") | trim %}
                          {% set parts.items = parts.items + ["Pflanzen die Naehrstoffe brauchen: " + clean] %}
                        {% endif %}
                        {% if both != "" %}
                          {% set clean = both | replace(both_text, "") | replace("\n", " ") | replace(":", "") | trim %}
                          {% set parts.items = parts.items + ["Pflanzen die Wasser und Naehrstoffe brauchen: " + clean] %}
                        {% endif %}
                        {% if night_temp is defined and night_temp | trim != "" %}
                          {% set parts.items = parts.items + [night_temp | trim] %}
                        {% endif %}
                        Achtung. {{ parts.items | join(". ") }}
                        type: tts
              # ── First action ───────────────────────────────────────────────
              - if:
                    value_template: !input action_1_status
                then:
                  - choose: []
                    default: !input action_1
      # ── High temp notification ─────────────────────────────────────────────
      - conditions:
            value_template: !input high_temp_enabled
        sequence:
          - parallel:
              # ── Mobile notifications ───────────────────────────────────────
              - repeat:
                  sequence:
                    - action: >-
                        message: "The temperature have been above {{ high_threshold }} for one hour,\n the temperature is now {{ states(temp_sensor) }}"
                        title: High temp alarm!
                          actions:
              - if:
                then:
                      message: "Achtung, Hochtemperaturalarm! Die Temperatur liegt seit einer Stunde über {{ high_threshold }} Grad. Aktuelle Temperatur: {{ states(temp_sensor) }} Grad."
                        type: tts
              - if:
                    value_template: !input action_1_high
                then:
                  - choose: []
      # ── Low temp notification ──────────────────────────────────────────────
      - conditions:
            value_template: !input low_temp_enabled
        sequence:
          - parallel:
              - repeat:
                  sequence:
                    - action: >-
                        message: "The temperature have been below {{ low_threshold }} for fifteen minutes,\n the temperature is now {{ states(temp_sensor) }}"
                        title: Low temp alarm!
                          actions:
              - if:
                then:
                      message: "Achtung, Niedrigtemperaturalarm! Die Temperatur liegt seit fünfzehn Minuten unter {{ low_threshold }} Grad. Aktuelle Temperatur: {{ states(temp_sensor) }} Grad."
                        type: tts
              - if:
                    value_template: !input action_1_low
                then:
                  - choose: []
    default:
      - stop: The plants feel fine
  # ── Persistent: wait for button press ─────────────────────────────────────
    value_template: '{{ persistent == true }}'
  - wait_for_trigger:
      - platform: event
        event_type: mobile_app_notification_action
        event_data:
          tag: flowerpower
          action_1_title: ok
          action_1_key: '"action_open"'
          action: '"action_open"'
  # ── Second action ──────────────────────────────────────────────────────────
  - if:
        value_template: !input action_2_active
    then:
      - choose: []
        default: !input action_2
  # ── Clear notification (all devices) ─────────────────────────────────────
  - repeat:
      sequence:
        - action: >-
            message: clear_notification
              tag: flowerpower
  # ── Third action ───────────────────────────────────────────────────────────
  - if:
        value_template: !input action_3_active
    then:
      - choose: []
        default: !input action_3
mode: single
