Hi all,
Is there a reason that the Plant Status card has so much padding around the 4 parameters (conductivity, temp, illuminance, moisture), but not between them? It looks fine when the card is full size, but if I want to put them in a 2x2 grid (or heaven forbid a 3x3 grid), all of the text gets scrunched together but there’s still a ton of padding around it. Is there some way to spread the text out so there’s less padding and will be less scrunched together?
I do have card-mod, but I can’t find a CSS way to put padding between the text. Is there some official way to do that, or am I just out of luck?
