🌿 PlantLab - AI plant health diagnosis for your grow room
I built a Home Assistant integration that diagnoses cannabis plant health from a camera photo and returns structured data your automations can act on - specific condition, confidence score, growth stage. Not a paragraph of text you have to read, but JSON that lets HA respond the same way it would to any sensor state change. I built this because I was tired of squinting at leaves under a blurple light at midnight trying to decide if I was looking at magnesium deficiency or early spider mites.
Fair warning: the models are trained specifically on cannabis. It will correctly reject non-cannabis photos, but it won’t diagnose your tomatoes.
What it does:
  • Service action plantlab.diagnose - pass a camera entity or image path
  • Returns structured JSON: health status, detected conditions, pests, growth stage, confidence scores
  • 30 classifiable issues (20 conditions + 10 pests) - calcium vs magnesium vs iron vs potassium individually, not “nutrient deficiency” as a bucket
  • 6 sensors update after each diagnosis (health, top condition, top pest, growth stage, nutrient analysis, binary problem sensor)
  • Nutrient analysis sensor runs Mulder’s Chart automatically - if it detects a deficiency, it flags which excess nutrients might be causing the lockout. So instead of “magnesium deficiency, add magnesium” it might tell you your calcium is too high and that’s the actual problem
  • Under a second per diagnosis
Because the output is structured, your automations can act on the result without a human reading it. Camera detects light burn? Dim the grow light. Nutrient deficiency? Adjust the dosing pump. Spider mites? Kill the intake fan so spores don’t spread to the next tent. The diagnosis is machine-readable, so HA treats it like any other sensor.
Example - diagnose and branch based on what’s detected:
automation:
  - alias: "Daily Plant Health Check"
      - platform: time
        at: "08:00:00"
      - action: camera.snapshot
          entity_id: camera.grow_tent
          filename: /config/www/plant_snapshot.jpg
      - action: plantlab.diagnose
          image_path: /config/www/plant_snapshot.jpg
        response_variable: diagnosis
      - choose:
          - conditions:
              - condition: template
                value_template: >
                  {{ 'light_burn' in diagnosis.conditions | map(attribute='class_id') | list }}
            sequence:
              - action: light.turn_on
                  entity_id: light.grow_light
                  brightness_pct: 70
          - conditions:
                value_template: "{{ diagnosis.is_healthy == false }}"
            sequence:
              - action: notify.mobile_app
                  title: "Plant Health Alert"
                  message: >
                    {{ diagnosis.conditions | map(attribute='class_id') | join(', ') }}
Light burn detected? Light dims to 70% automatically. Anything else unhealthy falls through to a notification. You could add branches for nutrient dosers, fan speed, irrigation - whatever your setup has. The structured response gives you the condition name and confidence to branch on.
Install:
HACS default listing is in the review queue. For now, add as a custom repository:
  1. HACS > Integrations > three dots menu > Custom repositories
  2. Paste: https://github.com/plantlab-ai/home-assistant-plantlab
  3. Category: Integration
  4. Install, restart, add via Settings > Devices & Services
Free tier is 3 diagnoses/day - enough for daily monitoring of a home grow. API key at plantlab.ai.
GitHub: GitHub - plantlab-ai/home-assistant-plantlab: PlantLab automation for Home Assistant · GitHub
I went with a service action instead of polling because most people want a check once or twice a day, not a camera hitting an API every 30 seconds. But the response is designed to be acted on programmatically - notification is just the simplest fallback. If you’ve got dosers, dimmable lights, or fan controllers wired into HA, the diagnosis data can drive all of them.
This is pretty slick. I tried a couple “plant doctor” apps a while back and they were always too vague, plus blurple lighting totally throws the camera off unless you snap pics under white light. The JSON output is the big win here since you can actually automate off it instead of staring at a paragraph and guessing. If you can keep false positives down (especially between cal/mag/iron), it’d be super useful for people running dosers because you can just gate changes on confidence or require 2 days in a row before adjusting anything.
On the automation side, I’ve had better results triggering off a consistent daily snapshot like you’re doing, and I’d probably add a “lights to 100% white for 10 seconds” scene before the photo, then flip back. Also worth adding an automation that tags the snapshot filename with date/time so you can look back when something goes sideways.
Not the same thing, but once you start trusting sensors and automations, it’s the same mindset as scaling production gear too. I got pointed at the AuraX automated pre roll machine when we were looking at higher-throughput automation and wanting actual reporting/consistency instead of vibes.
