Hi there, I’m Dennis, using HA for a couple of weeks now, so pretty a newbee. Forum searches helped me a lot to get my Instance working as I want it - but now I’m stuck.
I got climate_template working - almost. When choosing the hvac_mode, selection of modes works fine, only mode “off” is not working. As far as I tested it, the script is not invoked when choosing “off”. Any help apreciated.
configuration.yaml
- platform: climate_template
unique_id: "schlafzimmer_klimaanlage"
current_temperature_template: "{{ states('sensor.temp_schlafzimmer') | float }}"
target_temperature_template: "{{ states('input_number.schlafzimmer_target_temperature') | float }}"
hvac_mode_template: "{{ states('input_select.schlafzimmer_hvac_mode') }}"
fan_mode_template: "{{ states('input_select.schlafzimmer_fan_mode') }}"
modes:
- "off"
- "cool"
- "heat"
fan_modes:
- "low"
- "medium"
- "high"
- "auto"
min_temp: 16
max_temp: 30
set_temperature:
service: script.set_schlafzimmer_klimaanlage_temperature
data_template:
temperature: "{{ temperature }}"
set_hvac_mode:
- service: script.set_schlafzimmer_klimaanlage_mode
data_template:
hvac_mode: "{{ hvac_mode }}"
set_fan_mode:
service: script.set_schlafzimmer_klimaanlage_fan_mode
data_template:
fan_mode: "{{ fan_mode }}"
# Input for target temperature
input_number:
schlafzimmer_target_temperature:
name: "Target Temperature"
initial: 22
min: 16
max: 30
step: 1
# Input select for HVAC mode
input_select:
schlafzimmer_hvac_mode:
options:
- "off"
- "cool"
- "heat"
initial: "off"
schlafzimmer_fan_mode:
options:
- "low"
- "medium"
- "high"
- "auto"
initial: "auto"
# Input texts for storing IR codes
input_text:
schlafzimmer_klimaanlage_off:
initial: "Turn off"
schlafzimmer_klimaanlage_on:
initial: "Turn on"
schlafzimmer_klimaanlage_cool:
initial: "cool"
schlafzimmer_klimaanlage_heat:
initial: "heat"
schlafzimmer_klimaanlage_dry:
initial: "dry"
schlafzimmer_klimaanlage_fan_only:
initial: "fan"
schlafzimmer_klimaanlage_fan_low:
initial: "low"
schlafzimmer_klimaanlage_fan_medium:
initial: "medium"
schlafzimmer_klimaanlage_fan_high:
initial: "high"
schlafzimmer_klimaanlage_fan_max:
initial: "max"
schlafzimmer_klimaanlage_fan_auto:
initial: "auto"
scripts:
set_schlafzimmer_klimaanlage_temperature:
sequence:
- service: remote.send_command
metadata: {}
device: Mitsubishi_Climate
command: cool_temp_{{ states('input_number.schlafzimmer_target_temperature')
| int }}
entity_id: remote.universal_remote_1
set_schlafzimmer_klimaanlage_mode:
sequence:
metadata: {}
command: "{% if hvac_mode == 'cool' %}\n {{ states('input_text.schlafzimmer_klimaanlage_cool')
}}\n{% elif hvac_mode == 'heat' %}\n {{ states('input_text.schlafzimmer_klimaanlage_heat')
}}\n{% elif hvac_mode == 'dry' %}\n {{ states('input_text.schlafzimmer_klimaanlage_dry')
}}\n{% elif hvac_mode == 'fan_only' %}\n {{ states('input_text.schlafzimmer_klimaanlage_fan_only')
}}\n{% elif hvac_mode == 'off' %}\n {{ states('input_text.schlafzimmer_klimaanlage_off')
}}\n{% endif %}"
- service: climate.turn_on
metadata: {}
data: {}
entity_id: climate.schlafzimmer_klimaanlage
set_schlafzimmer_klimaanlage_fan_mode:
sequence:
metadata: {}
command: "{% if fan_mode == 'low' %} \n {{ states('input_text.schlafzimmer_klimaanlage_fan_low')
}}\n{% elif fan_mode == 'medium' %} \n {{ states('input_text.schlafzimmer_klimaanlage_fan_medium')
}}\n{% elif fan_mode == 'high' %} \n {{ states('input_text.schlafzimmer_klimaanlage_fan_high')
}} \n{% elif fan_mode == 'max' %} \n {{ states('input_text.schlafzimmer_klimaanlage_fan_max')
}} \n{% elif fan_mode == 'auto' %} \n {{ states('input_text.schlafzimmer_klimaanlage_fan_auto')
}}\n{% endif %}"
