When I update the files form https://github.com/jnimmo/home-assistant/tree/dev/homeassistant/components/intesishome my hassio breakes. I stop homeassistant, place those files in the costom_components folder then start homeassistant back up. It takes about 10 minutes and that’s it. My logs show the following:
`Error: Unknown Error, see logs
core-ssh:~# hassio homeassistant logs
File "/usr/src/homeassistant/homeassistant/config.py", line 772, in async_process_component_config
p_integration = await async_get_integration_with_requirements(hass, p_name)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 39, in async_get_integration_with_requirements
integration = await async_get_integration(hass, domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 286, in async_get_integrationg...
integration = Integration.resolve_legacy(hass, domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 181, in resolve_legacyocessing...
comp = _load_file(hass, domain, LOOKUP_PATHS)
File "/usr/src/homeassistant/homeassistant/loader.py", line 346, in _load_file
module = importlib.import_module(path)
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 724, in exec_module
File "<frozen importlib._bootstrap_external>", line 860, in get_code
File "<frozen importlib._bootstrap_external>", line 791, in source_to_code
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/config/custom_components/intesishome/__init__.py", line 7
<!DOCTYPE html>
SyntaxError: invalid syntax
File "/usr/src/homeassistant/homeassistant/setup.py", line 167, in _async_setup_component
hass, processed_config
File "/usr/src/homeassistant/homeassistant/components/onboarding/__init__.py", line 43, in async_setup
data = await store.async_load()
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 98, in async_load
return await self._load_task
concurrent.futures._base.CancelledError
File "/usr/local/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/local/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/src/homeassistant/homeassistant/__main__.py", line 407, in <module>
Exception in thread Thread-1:
File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.7/threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "/usr/src/homeassistant/homeassistant/util/logging.py", line 85, in _process
self._queue.get(), self.loop
File "/usr/local/lib/python3.7/concurrent/futures/_base.py", line 433, in result
raise CancelledError()
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 399, in main
exit_code = asyncio_run(setup_and_run_hass(config_dir, args))
File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
return loop.run_until_complete(main)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 579, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/__main__.py", line 302, in setup_and_run_hass
log_no_color=args.log_no_color,
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 150, in async_from_config_file
config_dict, hass, enable_log=False, skip_pip=skip_pip
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 95, in async_from_config_dict
await _async_set_up_integrations(hass, config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 376, in _async_set_up_integrations
*(async_setup_component(hass, domain, config) for domain in domains_to_load)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 562, in async_forward_entry_setup
result = await async_setup_component(self.hass, domain, self._hass_config)
File "/usr/src/homeassistant/homeassistant/setup.py", line 45, in async_setup_component
return await setup_tasks[domain] # type: ignore
File "/usr/src/homeassistant/homeassistant/setup.py", line 51, in async_setup_component
return await task # type: ignore
File "/usr/src/homeassistant/homeassistant/setup.py", line 136, in _async_setup_component
hass, config, integration
<!DOCTYPE html>
