Hello I have this error and can’t restart hassio, did I accidentally delete some integration?
how I can solve?
Probably you added an incorrect sensor-setup to either configuration.yaml or sensor.yaml or any other yaml where you keep sensors
I can’t find the button to validate the configuration anymore, where is it now?
Assuming you went to 2022.5 it should be in dev tools yaml tab… I am still on 2022.4.3
I don’t know how to look for the sensor with the wrong attribute …
Where do you define your sensors? What was the last you edited?
From your answer I assume you have not set this up too complex…so check the config folder (the one where configuration.yaml resides) and see which you updated last
Faund!
Thank you for support!
pls mark as resolved them
