I have created a group in the configuration.yaml so i can have a single entity for 2 desk lamps. I get a green tick in the file editor but when i do a config check before a server reboot i get Platform error switch.group - No module named ‘homeassistant.components.group.switch’ attached is the code i used. Is there something i’ve missed.
By putting the configuration under switch: you are effectively attempting to define a Switch Group. There’s no such thing as a Switch Group.
What you want is a Light Group so your configuration for Guest Room Lamps belongs under light: not switch:.
Is this the case even if i’m using wall switches to turn lamps on on off. eg, there making lights come on and off but really its 2 switches.
Light Group is for lights. It lets you control the brightness, color, etc of a group of lights as if they were a single light.
Simply create a standard Group containing your two switches. When you turn the group on/off, the two switches will turn on/off.
I have now just added Group then as a standard group. I also had the include groups.yaml in there. It doesn’t like something.
It has a green tick, but is the part about including groups.yaml right?
then the restart checker gives this.
i chnaged the kitchin to Guestroom
In your screenshot, you have a line indicating where the group-related information is located. It states that it is in a separate file called groups.yaml.
However, you didn’t add a new group in that file, you put it into configuation.yaml. Move it to the groups.yaml file.
Got it working. Thanks. You’ve been most helpful. Its a steep learning curve with HA, but enjoy that
You’re welcome. Glad to hear it’s working now.
Please consider marking my post (above) with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has an accepted solution. In addition, it will place a link below your first post that leads to the solution post. All of this helps other users find answers to similar questions.
