Found the answer to my questions
My custom ‘sensor.py’
import sys
import time
import struct
import array
from homeassistant.const import (
TEMP_CELSIUS, DEVICE_CLASS_HUMIDITY,
DEVICE_CLASS_TEMPERATURE)
from homeassistant.helpers.entity import Entity
REQUIREMENTS = ['pyserial==3.4']
import serial
import logging
_LOGGER = logging.getLogger(__name__)
def setup_platform(hass, config, add_entities, discovery_info=None):
"""Set up the sensors."""
add_entities([
multiHTU21DSensor('Temperature1', 11.6, DEVICE_CLASS_TEMPERATURE, TEMP_CELSIUS, None, 1),
multiHTU21DSensor('Temperature2', 12.6, DEVICE_CLASS_TEMPERATURE, TEMP_CELSIUS, None, 2),
multiHTU21DSensor('Temperature3', 13.6, DEVICE_CLASS_TEMPERATURE, TEMP_CELSIUS, None, 3),
multiHTU21DSensor('Temperature4', 14.6, DEVICE_CLASS_TEMPERATURE, TEMP_CELSIUS, None, 4),
multiHTU21DSensor('Temperature5', 15.6, DEVICE_CLASS_TEMPERATURE, TEMP_CELSIUS, None, 5),
multiHTU21DSensor('Temperature6', 16.6, DEVICE_CLASS_TEMPERATURE, TEMP_CELSIUS, None, 6),
multiHTU21DSensor('Temperature7', 17.6, DEVICE_CLASS_TEMPERATURE, TEMP_CELSIUS, None, 7),
multiHTU21DSensor('Temperature8', 18.6, DEVICE_CLASS_TEMPERATURE, TEMP_CELSIUS, None, 8),
multiHTU21DSensor('Humidity1', 10, DEVICE_CLASS_HUMIDITY, '%', None, 1),
multiHTU21DSensor('Humidity2', 20, DEVICE_CLASS_HUMIDITY, '%', None, 2),
multiHTU21DSensor('Humidity3', 30, DEVICE_CLASS_HUMIDITY, '%', None, 3),
multiHTU21DSensor('Humidity4', 40, DEVICE_CLASS_HUMIDITY, '%', None, 4),
multiHTU21DSensor('Humidity5', 50, DEVICE_CLASS_HUMIDITY, '%', None, 5),
multiHTU21DSensor('Humidity6', 60, DEVICE_CLASS_HUMIDITY, '%', None, 6),
multiHTU21DSensor('Humidity7', 70, DEVICE_CLASS_HUMIDITY, '%', None, 7),
multiHTU21DSensor('Humidity8', 80, DEVICE_CLASS_HUMIDITY, '%', None, 8),
class multiHTU21DSensor(Entity):
"""Representation of a sensor."""
handler = None
def __init__(self, name, state, device_class,
unit_of_measurement, battery, sensorNumber):
"""Initialize the sensor."""
self._name = name
self._state = state
self._device_class = device_class
self._unit_of_measurement = unit_of_measurement
self._battery = battery
self.sensorNumber = sensorNumber
if self.sensorNumber == 1 and self._device_class == DEVICE_CLASS_TEMPERATURE:
multiHTU21DSensor.handler = multiHTU21DSensorHandler()
@property
def should_poll(self):
return True
@property
def device_class(self):
"""Return the device class of the sensor."""
return self._device_class
@property
def name(self):
"""Return the name of the sensor."""
return self._name
@property
def state(self):
"""Return the state of the sensor."""
if self._device_class == DEVICE_CLASS_TEMPERATURE:
value = self.handler.get_temperature(self.sensorNumber)
else:
value = self.handler.get_humidity(self.sensorNumber)
return value
@property
def unit_of_measurement(self):
"""Return the unit this state is expressed in."""
return self._unit_of_measurement
def update(self):
"""Get the latest data and updates the states. Update only once for 16 sensors. """
self.handler.update()
class multiHTU21DSensorHandler:
"""Implement HTU21D communication."""
def __init__(self):
# Operations with Arduino and values storage
#self.temperatures = array.array('f')
#self.humidities = array.array('f')
self.temperatures = [10.0, 20.0, 30.0, 40.0, 50.0, 60.0, 70.0, 80.0]
self.humidities = [11.0, 21.0, 31.0, 41.0, 51.0, 61.0, 71.0, 81.0]
# Open port.
self.ser = serial.Serial('/dev/ttyUSB0', 115200) # open serial port
self.ser.timeout = 3
# Wait for port to get ready
time.sleep(3)
self.update()
def get_temperature(self, index):
"""Return the temperature of the sensor with index."""
return self.temperatures[index - 1]
def get_humidity(self, index):
"""Return the humidity of the sensor with index."""
return self.humidities[index - 1]
def update(self):
"""Read raw data and calculate temperature and humidity."""
# Send request.
self.ser.reset_input_buffer()
self.ser.write(1)
# Read 8 float values of temperature
rawData = self.ser.read(4 * 8)
self.temperatures.frombytes(rawData)
# Read 8 float values of humidity
self.humidities.frombytes(rawData)
Into ‘configuration.yaml’
- platform: multiHTU21D
