Platform hue does not generate unique ID problem
Hello Good morning, today i checked the hue motion sensor that i bind yesterday but it doesn’t show up in my Home Assistant and then i see the log and this shows up.
any ideas to solve this?
Thank You
I just purchased a HUE bridge and 2 bulbs. After setting up HUE bridge a 1 bulb, I connected with HA (no problems).
Then I moved the bulb (which was sitting in a tester plug) to another room to see if distance was ok. After this, I got the same message in logs and I couldn’t interact with the light though HA.
I restarted (Configuration → Server controls → Restart) and then it worked again.
Maybe this will work for you as well? Worth a try.
hi Michael, thank you for replying. actually i have found the solution. it seems like my hue sensor had been integrated with several hue bridge. so i removed the other integration that i didn’t need using philips hue app and it worked
Hi, this just started happening to me.
Restat of HA fixes this, but it’s happened twice now.
@Miftakhunnurudin I only have one bridge in my home, so not sure if how it could connect to several bridges. Maybe my neighbours?
