Platform rachio does not generate unique IDs
The Rachio platform does work. But I always get the errors in the logfile that the platform doen’t generate unique ID’s
How to solve?
Solved.
I found out that I still hat the old config for binary_sensor and switch.
I removed them now no more errors in the logfile.
@conradh - I have the same issue, what do you mean the “old config?” and what is the new one? I have it configured the same way as it is in the documentation, which is:
rachio:
  api_key: YOUR_API_KEY
and in the groups section something like this:
irrigation:
  icon: mdi:water-pump
  entities:
  - group.zones_front
  - group.zones_back
  - switch.side_yard
Thank you!
Sorry, my bad, I see what you mean.
What exactly did you do to remove those errors? I even tried to remove the entities directly from the registry and restarted. It looks like the components continues to recreate entities every time and the errors are still thrown…
