First and for all: wonderful thing home assistant! I’m using it know for a couple of weeks and I’m very enthusiastic!
I’ve upgraded last week to the newest version, but ever since my log is being spammed:
Message 1: “Platform songpal not ready yet. Retrying in XXX seconds.”
Message 2: “Unable to get methods from songpal: Got an error for getSupportedApiInfo: NoSuchMethod (12): getSupportedApiInfo”
Found somewhere on the internet: put the following in your configuration.yaml:
discovery:
ignore
-songpal
Clever solution, the errors go away. Unfortunately, my automations when I’m switching on my Bravia TV are not working anymore. If I delete the ignore songpal, it works again (but I get the spam in my log again).
Disabling songpal should not cause any changes to other components (such as braviatv), are you sure that is the problem?
Anyway, using the ignore should not be necessary so there is a bug in the autodetection detection routine. Could you execute songpal discover in your installation and post the contents to me so that I can fix it?
Ah, I see the problem now, some models seem to include the model number (MINT1.7.0.1 in your case) which I thought would not happen. I will need to find another way to exclude these devices – could you upgrade the python-songpal pypi package to the newest version with pip install -U python-songpal and then run songpal -d discover, and upload the printed out XML content somewhere?
