- platform: template not working anymore
Hi guys
We previously had this option, but with the newest update allot of these - platform all move for my case under
mqtt
What/how / where do I place this now though:, the below yaml basically enabled both my alarm zones
    panels:
      master_alarm_panel:
        code_arm_required: false
        value_template: >
          {% set p1 = states('alarm_control_panel.alarm_part1') %}
          {% set p2 = states('alarm_control_panel.alarm_part2') %}
          {{ p1 if p1 == p2 else 'pending' }}
        arm_away:
          - service: alarm_control_panel.alarm_arm_away
              entity_id:
                - alarm_control_panel.alarm_part1
                - alarm_control_panel.alarm_part2
        arm_home:
          - service: alarm_control_panel.alarm_arm_home
              entity_id:
        arm_night:
          - service: alarm_control_panel.alarm_arm_night
              entity_id:
        disarm:
          - service: alarm_control_panel.alarm_disarm
              entity_id:
That is not an mqtt sensor. It is a template sensor. It does not move anywhere.
it was defined under alarm_control_panel in configuration.yaml
under there was also some mqtt entities… see entire section below.
with all the mqtt entities removed… it still gave error… but figure it out, thanks for nudging me…
# Example configuration.yaml entry
alarm_control_panel:
  - platform: mqtt
    command_topic: "paradox/my/control/partitions/Inside"
    state_topic: "paradox/states/partitions/Inside/current_state"
    payload_arm_away: "arm"
    payload_arm_home: "arm_stay"
    payload_arm_night: "arm_sleep"
    payload_disarm: "disarm"
  - platform: mqtt
    command_topic: "paradox/my/control/partitions/Outside"
    state_topic: "paradox/states/partitions/Outside/current_state"
  - platform: mqtt
    command_topic: "paradox/control/partitions/Inside"
  - platform: mqtt
    command_topic: "paradox/control/partitions/Outside"
    panels:
      master_alarm_panel:
        value_template: >
        arm_away:
              entity_id:
        arm_home:
              entity_id:
        arm_night:
              entity_id:
        disarm:
              entity_id:
                - alarm_control_panel.alarm_part2    ```
