Play daily podcast from RSS feed – Mediaplayer or Sonos, Manual Bypass and Daily Limit
Play daily podcast from RSS feed – Version 6.4
This Blueprint retrieves the latest MP3 URL from a podcast RSS feed and
plays it on a selected media player.
Features
  • freely configurable rule-based triggers
  • additional playback conditions
  • once-per-day or unlimited rule-based playback
  • separate manual trigger that bypasses all conditions and the daily limit
  • Sonos snapshot and restore
  • optional Sonos group preservation
  • configurable Sonos volume
  • daily RSS update
Requirements
  • Home Assistant 2024.10 or later
  • Pyscript
  • a media player
  • Sonos integration when snapshot mode is used
  • four helpers
Download YAML and Pyscript
https://github.com/l3berwurst/daily-podcast-blueprint/tree/main
Required Helpers
Entity ID Type Purpose
input_text.dayly_podcast_mp3_url Text Stores the MP3 URL
input_number.tagesschau_99sek_volume Number Sonos volume
input_boolean.tagesschau_99sek_podcast_playing Toggle Playback marker
input_boolean.tagesschau_99sek_1x_morgens_merker Toggle Once-per-day marker
Additional Installation
The Blueprint also requires the Pyscript:
/config/pyscript/daily_podcast_rss_EN.py
GitHub repository:
Full English guide:
https://github.com/l3berwurst/daily-podcast-blueprint/blob/main/GUIDE_EN.md
Complete Package
https://github.com/l3berwurst/daily-podcast-blueprint/blob/main/daily_podcast_v6_4_english.zip
The ZIP package contains:
  • English Blueprint
  • shared Pyscript
  • helper YAML
  • German guide
  • English guide
  • README
Blueprint YAML
blueprint:
  name: Daily Podcast on a Media Player – Version 6.4 en
  description: >-
    Plays the latest podcast MP3 using freely configurable rule-based triggers
    or a separate manual trigger. Rule-based triggers observe additional
    conditions and can optionally be limited to one successful start per day.
    The manual trigger bypasses these conditions and the daily limit
    completely. Sonos players can use snapshot, podcast volume, and restore.
  domain: automation
  homeassistant:
    min_version: 2024.10.0
  input:
    start_und_bedingungen:
      name: Start Triggers and Conditions
      description: >-
        Configure rule-based triggers and a separate manual trigger that can
        start playback at any time, independently of conditions and the daily
        limit.
      input:
        playback_triggers:
          name: Rule-based Podcast Start Triggers
          description: >-
            Add one or more Home Assistant triggers. These triggers observe
            the additional playback conditions. Examples include state
            changes, sensor values, times, motion sensors, calendar events,
            or NFC tags.
          default:
            - trigger: numeric_state
              entity_id:
                - sensor.clagehomeserver_dsxtouchserver_heater_status_power
              below: 1
              for:
                hours: 0
                minutes: 0
                seconds: 20
          selector:
            trigger: {}
        playback_conditions:
          name: Additional Conditions for Rule-based Playback
          description: >-
            Optional. These conditions apply only to the rule-based podcast
            start triggers. The manual trigger ignores every condition entered
            here.
          default:
            - condition: time
              after: "05:30:00"
              before: "06:30:00"
          selector:
            condition: {}
        manual_trigger:
          name: Manual Trigger – Bypass Conditions and Daily Limit
          description: >-
            This binary sensor starts the podcast only when it changes to ON.
            Additional conditions, time windows, and the once-per-day limit
            are not checked. The later change back to OFF does not start a
            second automation run.
          default: binary_sensor.c5_bad_knx_haas_podcast_spielen
          selector:
            entity:
              filter:
                - domain: binary_sensor
    tagesbegrenzung:
      name: Rule-based Starts per Day
      description: >-
        Choose whether rule-based triggers may start the podcast only once or
        an unlimited number of times per day. The manual trigger is never
        restricted by this setting and does not modify the daily marker.
      input:
        daily_start_policy:
          name: Number of Rule-based Starts
          description: >-
            “Once per day” checks and sets the daily marker selected below.
            “Unlimited per day” ignores the daily marker completely. The
            manual trigger bypasses both options.
          default: once
          selector:
            select:
              mode: list
              options:
                - label: Once per day
                  value: once
                - label: Unlimited per day
                  value: unlimited
        daily_marker:
          name: Daily Marker for “Once per Day”
          description: >-
            This input_boolean is checked only when “Once per day” is selected,
            set after a successful rule-based start, and switched off at the
            fixed reset time. It is ignored completely for “Unlimited per day”
            and for the manual trigger.
          default: input_boolean.tagesschau_99sek_1x_morgens_merker
          selector:
            entity:
              filter:
                - domain: input_boolean
    podcast_ausgabe:
      name: Media Player and Helpers
      description: >-
        Select the media player and choose whether the Sonos snapshot feature
        should be used.
      input:
        media_player:
          name: Media Player for the Podcast
          description: >-
            The podcast MP3 is played on this media player. The default value
            is the configured bathroom Sonos player.
          default: media_player.bad
          selector:
            entity:
              filter:
                - domain: media_player
        sonos_mode:
          description: >-
            No: Play the MP3 only, without snapshot, restore, or volume change.
            Yes without group: Use Sonos snapshot and restore without the group
            composition. Yes with group: Use Sonos snapshot and restore,
            including the Sonos group. Select a Yes option only for an entity
            provided by the Sonos integration.
          default: sonos_group
          selector:
            select:
              mode: list
              options:
                - label: No – Play Only
                  value: none
                - label: Yes – Snapshot without Group
                  value: sonos
                - label: Yes – Snapshot with Group
                  value: sonos_group
        volume_helper:
          description: >-
            This input_number helper defines the volume as a percentage. It is
            used only when a Sonos Player option is enabled.
          default: input_number.tagesschau_99sek_volume
          selector:
            entity:
              filter:
                - domain: input_number
        mp3_url_helper:
          name: Helper for the Current MP3 URL
          description: >-
            This input_text helper stores the direct MP3 URL retrieved by the
            Pyscript.
          default: input_text.dayly_podcast_mp3_url
          selector:
            entity:
              filter:
                - domain: input_text
        playing_helper:
          name: “Podcast Is Playing” Marker
          description: >-
            Switched on after playback has been confirmed and switched off
            again after playback ends or the timeout is reached.
          default: input_boolean.tagesschau_99sek_podcast_playing
          selector:
            entity:
              filter:
    rss_update:
      name: RSS Feed and Update
      description: >-
        Set the RSS feed and the daily update time.
      input:
        rss_url:
          name: RSS Feed URL
          description: >-
            Address of the podcast RSS feed. The Pyscript retrieves the MP3
            URL from the first item.
          default: "https://www.tagesschau.de/multimedia/sendung/tagesschau_in_100_sekunden/podcast-ts100-audio-100~podcast.xml"
          selector:
            text:
              type: url
              multiline: false
        update_time:
          name: Daily RSS Update Time
          description: >-
            At this time, the current MP3 URL is retrieved from the RSS feed.
          default: "04:00:00"
          selector:
            time:
    wiedergabe:
      name: Playback and Timeouts
      description: >-
        Configure how long the automation should wait for playback to start
        and finish.
      input:
        playback_start_timeout:
          name: Playback Start Timeout
          description: >-
            The media player must reach the “playing” state within this time.
            Only then is the daily marker set for a rule-based start when
            “Once per day” is selected.
          default:
            hours: 0
            minutes: 0
            seconds: 10
          selector:
            duration:
        max_playback_duration:
          name: Maximum Podcast Playback Time
          description: >-
            After this time, the automation stops waiting for playback to end.
            If a Sonos mode is enabled, the snapshot is then restored.
          default:
            hours: 0
            minutes: 3
            seconds: 0
          selector:
            duration:
variables:
  media_player_entity: !input media_player
  mp3_url_helper_entity: !input mp3_url_helper
  volume_helper_entity: !input volume_helper
  sonos_mode_value: !input sonos_mode
  use_sonos_snapshot_value: >-
    {{ sonos_mode_value in ['sonos', 'sonos_group'] }}
  sonos_with_group_value: >-
    {{ sonos_mode_value == 'sonos_group' }}
  daily_start_policy_value: !input daily_start_policy
  daily_marker_entity: !input daily_marker
  trigger_id_value: >-
    {% if trigger is defined and trigger.id is defined %}
      {{ trigger.id }}
    {% else %}
    {% endif %}
  daily_limit_enabled: >-
    {{ daily_start_policy_value == 'once' }}
  is_manual_bypass: >-
    {% set current_trigger_id = trigger_id_value | trim %}
    {{ current_trigger_id == ''
       or current_trigger_id ==
          '__daily_podcast_v6_2_manual_bypass_trigger__' }}
triggers:
  - trigger: state
    entity_id: !input manual_trigger
    to: "on"
  - triggers: !input playback_triggers
  - trigger: time
    at: "00:00:01"
  - trigger: time
    at: !input update_time
conditions: []
actions:
  - choose:
      - alias: Reset daily marker
        conditions:
          - condition: template
            value_template: >-
              {{ trigger_id_value | trim ==
                 '__daily_podcast_v6_internal_marker_reset__' }}
        sequence:
          - alias: Reset only in Once per Day mode
            if:
                value_template: "{{ daily_limit_enabled }}"
            then:
              - action: input_boolean.turn_off
                continue_on_error: true
                  entity_id: "{{ daily_marker_entity }}"
      - alias: Retrieve current MP3 URL from RSS feed
        conditions:
            value_template: >-
                 '__daily_podcast_v6_internal_rss_update__' }}
        sequence:
          - action: pyscript.update_tagesschau_mp3_url
              rss_url: !input rss_url
              mp3_url_helper: !input mp3_url_helper
    default:
      - alias: Check additional conditions only for rule-based starts
        condition: or
        conditions:
            value_template: "{{ is_manual_bypass }}"
          - condition: and
            conditions: !input playback_conditions
      - alias: Check daily limit only for rule-based starts
        condition: template
        value_template: >-
          {{ is_manual_bypass
             or not daily_limit_enabled
             or is_state(daily_marker_entity, 'off') }}
      - alias: Continue only with a valid MP3 URL
        condition: template
        value_template: >-
          {% set url = states(mp3_url_helper_entity) %}
          {{ url not in ['', 'unknown', 'unavailable', 'none'] and
             url.startswith(('http://', 'https://')) }}
      - alias: Continue only when the media player is available
        condition: template
        value_template: >-
          {{ states(media_player_entity) not in
             ['unknown', 'unavailable', 'none'] }}
      - alias: Clear a stale podcast-playing marker
          entity_id: !input playing_helper
      - alias: Create a snapshot for Sonos
        if:
            value_template: "{{ use_sonos_snapshot_value }}"
        then:
          - action: sonos.snapshot
              entity_id: !input media_player
              with_group: "{{ sonos_with_group_value }}"
          - alias: Set podcast volume only for Sonos
            action: media_player.volume_set
              volume_level: >-
                {% set volume =
                   (states(volume_helper_entity) | float(30)) / 100 %}
                {{ [0, [volume, 1] | min] | max | round(2) }}
          - delay:
              milliseconds: 300
      - alias: Play podcast MP3
        action: media_player.play_media
          media_content_id: "{{ states(mp3_url_helper_entity) }}"
          media_content_type: music
      - alias: Wait for confirmed playback start
        wait_template: "{{ is_state(media_player_entity, 'playing') }}"
        timeout: !input playback_start_timeout
        continue_on_timeout: true
      - alias: Set markers and wait for the end only after a successful start
        if:
            value_template: "{{ wait.completed }}"
        then:
          - alias: Set daily marker only for a rule-based start
            if:
                value_template: >-
                  {{ not is_manual_bypass and daily_limit_enabled }}
            then:
              - action: input_boolean.turn_on
          - alias: Turn on the podcast-playing marker
          - alias: Wait for end, pause, stop, or timeout
            wait_for_trigger:
              - trigger: state
                for:
                  seconds: 1
            timeout: !input max_playback_duration
      - alias: Turn off the podcast-playing marker
      - alias: Restore Sonos snapshot only when a Sonos option is enabled
        if:
        then:
          - action: sonos.restore
mode: single
max_exceeded: warning
Helper YAML
# Home Assistant helpers for Daily Podcast – Version 6.4
# This file can be used as a Home Assistant package, for example:
# /config/packages/daily_podcast_helpers_EN.yaml
# Required configuration in configuration.yaml:
# homeassistant:
#   packages: !include_dir_named packages
# Alternatively, merge the input_text, input_number, and input_boolean
# sections below into the corresponding existing sections in
# configuration.yaml.
input_text:
  dayly_podcast_mp3_url:
    name: Daily Podcast MP3 URL
    icon: mdi:link-variant
    max: 255
    mode: text
input_number:
  tagesschau_99sek_volume:
    name: Daily Podcast Sonos Volume
    icon: mdi:volume-high
    min: 0
    max: 100
    step: 1
    unit_of_measurement: "%"
    mode: slider
    initial: 30
input_boolean:
  tagesschau_99sek_podcast_playing:
    name: Daily Podcast Is Playing
    icon: mdi:podcast
  tagesschau_99sek_1x_morgens_merker:
    name: Daily Podcast Already Played Automatically Today
    icon: mdi:calendar-check
