I have integrated my kodi instance with HA.
Now I want to be able to play a Kodi folder that contains music with a trigger; button, or state etc.
While being familiar with the triggering part, I am completely at sea with regards to how to play music from the folder located at \storage\music on the kodi host. I am unable to find very relevant documentation on the same either. Appreciate any help. Thank you.
I do not play a folder, but a file (file path is given by a trigger). Maybe it helps anyway…
- id: '1639043665489'
alias: Play on Kodi
description: ''
- platform: event
event_type: play_on_kodi_wz
condition: []
- service: media_player.play_media
media_content_id: '{{ trigger.event.data.filepath }}'
media_content_type: file
entity_id: media_player.kodi_wz_2
mode: restart
Sorry I didnt understand … (file path is given by a trigger)
In my case, a local webserver fires an event via HA’s REST API. This event is called “play_on_kodi_wz” and the event data contains the file path (e.g. “/storage/media/my_movie.mp4”).
Background is: I use a webpage that lists all my videos, and by a click on a file name (a link), the webserver fires the event on HA. But that doesn’t matter for HA, it just gets an event with a file path.
I don’t know enough about your problem to help further. Do you want to play a specific file from a folder or all files from that folder? Is it always the same path or where does the path come from? Things like that
Well actually the file resides on the same machine as HA and so does the Kodi instance (Kodi on Coreelec, and HA running dockerised).
I would ideally like to play all the files in the folder.
The path of the folder is \storage\music as far as kodi is concerned.
I would prefer my trigger to be something like 8 am in the morning on weekdays. Or lets say when I switch off a certain light which I do every morning.
In the docs of the kodi integration you find this:
media_content_type: DIRECTORY
media_content_id: special://profile/playlists/video/feuerwehrmann_sam.xsp
look like just starting a “smart play list” is a good way to do that. Creating such a playlist can be easily done in kodi and can by dynamic. So I’d try that way.
For details on creating smart play lists, you can start here:
https://kodi.wiki/view/Smart_playlists/XSP_Method
This seems too much and unneccessary. I dont wish to create a playlist etc. because I will have to edit it each time I add or remove new music.
Lets leave kodi out. Is it possible for HA to use some other player (or a built in player if there is one) to merely play music from a folder?
Edit: The media files can reside on the same R Pi I am using as the HA server. And would like to use the analog audio output of the Pi for sound output.
